How many turns on idle air bypass screw
98 Civic EX 4-door sedan Automatic D16Y8
I'm having idle speed problems, but I have not yet tried to adjust. The shop manual says adjust idle speed with the IACV connected, and to adjust by means of the air bypass screw. The screw when I checked it was less than 1/2 turn open from the fully closed position. Is that reasonable, or have others found it necessary to open the screw more turns? Or is there no "rule of thumb" at all as to how many turns are typical?
I also found a TSB that says the PCM will "learn" new settings for the IACV after adjustments are made to the screw. Is that true for my specific model?
Thanks any advice!
Thanks any advice!
jeffbrewer80
Jun 23, 2012 05:27 AM
Excelerate
Jun 18, 2005 07:16 AM
b16acrxer
Aug 31, 2004 09:02 AM
