Suspension & Brakes Theory, alignment, spring rates....
Re-raising a honda civic
Old Sep 25, 2012 | 04:29 PM
orb360's Avatar
Default Re-raising a honda civic
The previous owner of my '96 civic cut the springs and they've relaxed and now the car is too low to pass safety and emissions (Utah... bleh)
Anyways. I got some stock struts, pulled out the old one, put the new one in.
However, I can't get the bottom bolt hole on the strut knuckle to align with the bearing. The wishbone won't go down far enough to line up. It's about an inch too high.
Do I need to re-adjust the tie rod length in order to drop it down more?
I've could probably strong arm it into place with a couple people but I've heard that can damage stuff.
Thanks
Here's some pics:
Old Sep 25, 2012 | 04:50 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Re-raising a honda civic
I would take a floor jack and jack it up some under the fork to compress the spring and then release. It may stay compressed enough to get the bolt in.
Old Sep 25, 2012 | 04:52 PM
orb360's Avatar
Wow... that is so simple I feel stupid now lol...
I'll give it a go!
:D
Old Sep 25, 2012 | 05:18 PM
98civdx's Avatar
Master Detailer
Jack the fork up gently. I've had to do it a few times.
Old Sep 25, 2012 | 06:49 PM
orb360's Avatar
keeps sliding off to the side so the holes don't line up.
Won't stay compressed at all, although maybe that's a good thing.
Trying to tie the strut back so it won't slide so much, but can't get enough tension to keep it lined up right either :/
Old Sep 25, 2012 | 07:31 PM
orb360's Avatar
Ok, I got it.
Had to have my friend hold the rotor down. Used the jack to push the strut up. Used bailing wire to hold the strut to the chassis so it wouldn't slide out... Then finally used a pair of channel locks to twist that sucker into the right orientation.
What a pain in the butt!
Now to do the other side lol
Thanks for the help :D
Old Sep 25, 2012 | 07:39 PM
chiprez's Avatar
Simple. Pry down on the LCA and push the bottom of the strut in.
Old Sep 26, 2012 | 11:33 AM
.brad's Avatar
25 Year Member
Originally Posted by orb360
Ok, I got it.
I've had to stand on the rotor and bounce on it a little to get it to go into place...
Old Sep 26, 2012 | 05:07 PM
TunerN00b's Avatar
Did someone forget to disconnect the swaybar before attempting this?
Swaybars tie the 2 sides of the suspension together through a torsion spring. If you're trying to force one side further into droop, the swaybar will fight against this...
Old Sep 26, 2012 | 05:14 PM
grumblemarc's Avatar
The Grumpiest
Never had to disconnect a swaybar when working on the front of the car. Use the scissor jack.
posthuman63t
Suspension & Brakes
Jun 9, 2012 12:28 PM
garthjenkins
80
Apr 24, 2011 05:13 PM
hastingsr
Suspension & Brakes
12
Jun 24, 2010 06:49 AM
204snic
Dec 27, 2009 06:08 AM
biggjerryc
14
Aug 9, 2008 08:46 PM
