will coupe door fit hatchback??
thx flip and SJ for your help that makes my life a tone easier that i dont have to fix my door now jus another question.
is it easy to swap windows? because my windows are tinted and dont wanna waste money on new tint. and if so how do you swap windows??
take panel off. roll window up/down till the 2 10mm bolts that bolt the window to the lift arms line up with 2 holes on the door. loosen them, slide either the window or track (can't remember) so they will pop out, HOLDING THE WINDOW. slide the back up first so the window in angled and lift up outa the door.
Installation is in reverse, just make sure the window doesn't into the front and rear tracks. Then roll it up and down to make sure the side tracks don't need adjusting.
To adjust the front track there is a 10mm bolt down at the bottom right(drivers side) that you can lossen to move the track a little.
marylou
12
Jul 7, 2010 08:40 AM
Shaynepolevault
May 12, 2009 11:01 AM
slackeR1366
Northeast (Sales)
16
Jul 23, 2008 01:54 PM
