97 civic lx. Driver but needs work $1,500 or trade?
Here's the deal, put a lot of time into this car and im just done messing with it. suspension was just done and has a small clunk not sure where its coming from. makes the noise when starting out in first gear. The motor just started clattering and I have had enough. I think it may be the input shaft bearing but to be honest I'm not sure. The car is 100% driveable and can be driven daily, motor is just making noise.
*1997 civic lx.
18x,xxx miles
THE BAD
-the car has a rebuilt title
-leaking oil between engine and trans(which is also why i think it's the input shaft bearing)
-the car is rattle canned flat tan. paint is flaking and tiger stripped. driver's fender sticker bombed. The car has dent's dings and rust. rust isn't very bad though
-interior is in ok condition
-NO ac, power steering, or cruise.
The Good
*Brand new windshield
*New front brakes(rotors and pads)
*all four shocks are brand new
*new energy suspension bushings in front upper and lower control arms, shock mounts, and energy suspension tie rod boots
*all new suspension hardware
*new no name rear lca
*brand new exhaust from the header back
*99-00 si front end conversion. hood is in bad shape and bare metal
I can't think of anything else at the moment if I do I will update this post. I want this gone asap. $1,500 firm firm firm, or trade for a need nothing daily driver.
You can call or text me anytime at 262-661-3950.
*1997 civic lx.
18x,xxx miles
THE BAD
The Good
^^ you are correct sir. meant to say that I think the leak is coming from the input shaft seal and the rattle is coming from the input shaft bearing. But upon further inspection I believe that its leaking from the seal where the shift linkage enters the transmission.
http://hondamarketplace.com/showthread.php?t=3090599
Check out my link maybe u wanna trade for something
BoostedEF
13
May 6, 2007 07:16 AM
Sean @ ESG
22
Nov 21, 2005 08:18 PM
equalizir
Jan 22, 2004 02:20 PM
