Clunking noise still there - worse
Well, some of you might remember me posting a thread about a clunking noise I have been experiencing with my car. At first I thought it was axles, it wasnt, then I replaced the tie arm and it wasn't that. Now I'm thinking ball joint, or my upper a-arm bushing.
But experiencing it more and more, its too loud to be a worn bushing, and it seems like its coming from the middle front of the car. Like right behind the engine.
Could it be an engine mount? I have a 00 civic si by the way.
Just trying to get more input on it because I think it might be getting to the point where its damaging something
I dont wanna throw down a bunch of cash for a suspension part thats not gonna work.
Thanks!
Thanks!
Unceasing Measure
Re: Clunking noise still there - worse (turbod16y7)
Mileage and level of abuse on the car from 1 - 10. The stock motor mounts are soft as **** and they rip and break easilly. It would be an easy fix if you could get under there and tell us that's what it is.
Unceasing Measure
Re: (banzai msg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg »</TD></TR><TR><TD CLASS="quote">I have place racing polyurethane mounts - all but the back mount</TD></TR></TABLE>
...And you didn't consider that maybe the vibrations being redirected by your stronger mounts would greately lessen the life of the one mount you chose not to reinforce? I'd crawl under there right now and see if anything is still functional. Any dimples in the hood yet?
oh my bad. I'm sorry, I meant all but the front. I was thinking about the back mount when I typed that _ edited now
I have 3 of the 4 replaced with placeracing ones. The left right and back
My rear mount has started clunking after a few redlines in first... yeah those motor mounts are piece of ****.. it's most likely the rear motor mount allowing the motor to move excessively
Re: (civic_driver)
do this, jack the front of your car up, stick your lug wrench into the coils of your springs and lay it down on the top of your upper control arm. now pul downwards on the lug wrench, if the upper balljoint moves, its bad, i had the same problem, baught a new upper control arm from honda (balljoints dont come seperate) and replace that thing, no more clunk for me!
Re: (banzai msg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg »</TD></TR><TR><TD CLASS="quote">hmmm...nothing?
It happens when I shift in low gears, or get on/off the gas abrubtly</TD></TR></TABLE>
So then its obviously something directly effected by torque... but that doesn't really help to narrow things down much. I would start by inspecting ALL the engine mounts, especially the driver side top mount. This one is commonly torn on EK's. If all the engine mounts check out, then move on to the suspension. Using a rubber mallet, tap the upper ball joint, lower ball joint, tie rod... whatever. Don't beat the **** out things, but you should be able to find fault by lightly tapping on things. If anything is loose or worn, it should show up.
Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
So then its obviously something directly effected by torque... but that doesn't really help to narrow things down much. I would start by inspecting ALL the engine mounts, especially the driver side top mount. This one is commonly torn on EK's. If all the engine mounts check out, then move on to the suspension. Using a rubber mallet, tap the upper ball joint, lower ball joint, tie rod... whatever. Don't beat the **** out things, but you should be able to find fault by lightly tapping on things. If anything is loose or worn, it should show up.</TD></TR></TABLE>
My driver side mount is completely torn(from a clutch job) and i don't have the clunking problem. The shifting in low gears/letting off the gas abruptly makes it sound like the rear torsion mount(against the firewall). The clunking occurs right when you let out the clutch and depress the throttle, correct?.
Re: (EJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ7 »</TD></TR><TR><TD CLASS="quote">
My driver side mount is completely torn(from a clutch job) and i don't have the clunking problem. The shifting in low gears/letting off the gas abruptly makes it sound like the rear torsion mount(against the firewall). The clunking occurs right when you let out the clutch and depress the throttle, correct?.</TD></TR></TABLE>
A lot of EK's have torn mounts. Its just something to look for. Of course its not going to cause the clunkning, its not a torque mount. I was simply listing it as something to search for WHILE inspecting the other mounts. You know?
Mr. Indecisive
Re: (Hybrid93Eg)
am i wrong by sayin it could be the differential?? do u have lsd??? U said its comming from around the trans right?? Also maybe the itermediate shaft/shaft berrings??
Re: (Hybrid93Eg)
A lot of EK's have torn mounts. Its just something to look for. Of course its not going to cause the clunkning, its not a torque mount. I was simply listing it as something to search for WHILE inspecting the other mounts. You know?</TD></TR></TABLE>
The engine rocks forward to back as you drive, if your rear mount is broken the engine has more room to rock, the rear mount(if that is the problem) would be an <U>indirect</U> cause of the clunking. BTW, all engine mounts are torque mounts.
Re: (EJ7)
yea ej, the clunking happens right as i let off/or get on the gas or clutch. It also sounds like its happening right at the firewall. Where is the rear torsion mount located?
Re: (EJ7)
BTW, all engine mounts are torque mounts.</TD></TR></TABLE>
Incorrect.
Incorrect.
Mr. Indecisive
Re: (banzai msg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg »</TD></TR><TR><TD CLASS="quote">yea ej, the clunking happens right as i let off/or get on the gas or clutch. It also sounds like its happening right at the firewall. Where is the rear torsion mount located?</TD></TR></TABLE>
sounds like it could be the intermediate shaft, mine clunks a little also when i hit the gas at low rpms especially
Re: (banzai msg)
It's right below(about 7inches) your throttle body, where the actual lip of your air intake and throttle body meet. You might need a mirror on a stick to look at it seeing as how it faces left/right.
Re: (banzai msg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg »</TD></TR><TR><TD CLASS="quote">is it attached to the engine, or transmission, or part of the axle assembly?</TD></TR></TABLE> Engine.
AcCO12D95
02-15-2018 04:59 PM
sedorbrian
02-01-2012 01:53 AM
jadedasn
03-06-2002 02:50 PM
