Need a 02 sensor whats best factory replacement?
Old Sep 24, 2012 | 12:28 PM
underrated99si's Avatar
Icon2 Need a 02 sensor whats best factory replacement?
MY 2nd o2 sensor got stuck in my aftermarket cat and would not come out & i sold it with the rest of my spoon exhaust.
I need a new one but not sure what best factory replacement would be that has the factory connector as well. Most of them i have scene are splice set ups & I dont want to pay 300 the dealer wants for a new one.
Also is it gona be a A/F problem if I drive my ITR with a open header just cruising on the freeway to my local exhaust shop. I didnt know that the SMSP set up was not bolt up and needed to be welded up. I have the JDM final drive and rpms on freeway would be 3900-4000K
Thanks for any feedback
-CHris
Old Sep 24, 2012 | 12:45 PM
IN VTEC's Avatar
Default Re: Need a 02 sensor whats best factory replacement?
Look up the denso part number for your car at http://www.sparkplugs.com then search for that part number on amazon.com to see if it's cheaper.
If you throw a code getting to the shop just pull the ecu fuse for > 30? seconds after its done. The ecu will relearn the STFT and LTFT with the new exhaust.
Old Sep 24, 2012 | 02:32 PM
Thanks for the link
The 02 sensor in the cat is that the upstream or downstream one? I assume its the down stream but just want to make sure
-Chris
Old Sep 24, 2012 | 03:06 PM
IN VTEC's Avatar
Before is upstream. After is downstream.
Old Sep 24, 2012 | 04:57 PM
luvmihatch's Avatar
Bosh. thats what ive used and they are great.
Old Sep 24, 2012 | 06:23 PM
kyosoeg6's Avatar
You can get the correct denso replacement from autozone .com. Come with a few year warranty also
Old Sep 30, 2012 | 05:57 AM
Dave_B's Avatar
I've got a used OEM one FS... you have PM.
Old Sep 30, 2012 | 07:57 AM
coolhandluke's Avatar
I'v used NGK PN 24172 many time throughout my vehicles:
http://www.ngk.com/results_cross.asp...4172&x=65&y=14
http://www.team-integra.net/forum/11...placement.html
Old Sep 30, 2012 | 11:03 AM
racebum's Avatar
NTK and Denso, either is a great choice
amazon usually carries both and or rock auto. the upstream is cheap, normally $40 or so
Old Oct 2, 2012 | 10:35 PM
Trimax2's Avatar
You can get the exact oem replacement denso one from rockauto.com for cheap I paid $30 shipped for mine I think it was the upstream if I remember right. I know the dude in parts at Acura and took it to him to give him a hard time he asked where I got it cause its the exact same as he had and he wanted to buy one at the price I got it lol
Old Oct 4, 2012 | 07:05 AM
heel_touge's Avatar
Do not go bosch or anything other than denso with OEM direct fit, have replaced three lesser brand sensors amongst friends cars.
rowo87
Honda Civic (2001 - 2005)
Mar 31, 2010 10:38 PM
turboedsupe
Apr 29, 2009 05:31 PM
maxflame
May 17, 2007 07:19 PM
pornstarSR
Nov 25, 2002 12:25 PM
