Help diagnose h22a swapped accord
Old Sep 24, 2012 | 11:49 AM
DDream's Avatar
Default Help diagnose h22a swapped accord
So i been trying to fix this the last couple days and no luck... had map sensor CEL but i got that fixed
o2 is disabled same with knock sensor
SYMPTOMS: Hard to start and when running i have to keep revving or it dies out... seems to run fine when going above 2500rpm.
Misfires, smells like unburnt gas and decent amount of white smoke
when it dies down i "burbs" white smoke out intake
FIXED:
map sensor CEL
Checked mechanical timing
calibrated TPS
New spark plugs
fpr and injectors off of running car
NEXT:
valve lash clearances
Egr valve
How do i check the external coil if its gone bad?
any ideas?
Old Sep 24, 2012 | 10:05 PM
holmesnmanny's Avatar
Default Re: Help diagnose h22a swapped accord
What do you mean o2 is disabled ? Why would you want it disabled ?
White smoke normally means issues with the engine. What are your compression test numbers ?
Old Sep 25, 2012 | 07:01 AM
DDream's Avatar
it was 190 across
its disabled so it rules out that its the o2 reading wrong... would it help if its enabled?
i have it disabled on my turbo cars and never caused this problem
Old Sep 25, 2012 | 07:07 PM
v4lu3s's Avatar
RTFM
what ecu do you have?
Posted from Honda-tech.com App for Android
Weakbyyou
Jan 29, 2010 09:29 AM
JDM-KIDD
Aug 31, 2009 05:56 PM
GaTaMaX
Apr 9, 2008 06:28 PM
Sick'Lude
Sep 21, 2005 11:32 AM
nfn15037
Jan 18, 2002 01:16 PM
