Transmission & Drivetrain Gearboxes, Differentials, Clutches
D series Trans Question
Old Sep 24, 2012 | 07:45 AM
grt009's Avatar
10 Year Member
Default D series Trans Question
Ok so I'm pretty sure I have a bad input shaft bearing in my trans. So I want to buy my self a used trans from a junkyard or craigslist or something. And swap them out.
I have a 98 civic dx and I believe my transmission says s40 on it and if im not mistaken there are a few different trans for the d series. So do i just need to get another one that says s40 and i will have all the same gear ratios and it will fit?
Also is there any thing i can look for when buying a used trans? I know its kinda a crap shoot but if you have any tips let me know
thanks
Old Sep 24, 2012 | 07:52 AM
bgdriver's Avatar
Default Re: D series Trans Question
Why not replace the ISB And seal and keep the old trans?
THE s40 means nothing, the code you want is by the passenger side of the diff.
Old Sep 24, 2012 | 08:19 AM
grt009's Avatar
10 Year Member
ok thanks for the help
I just want to swap one in because its what I feel comfortable doing. Never took a trans apart and i need it to go quick.
Old Sep 24, 2012 | 04:41 PM
94EG8's Avatar
Seagull Management
If you're buying a used trans replace the ISB before you put it in. I'd say 8 out 10 will have a bad ISB.
It's really hard to tell a good transmission from a bad one without taking it completely apart. Even with the case off a lot of stuff isn't readily apparent. You really need to take the trans apart and clean everything up to truly see whats good and what isn't.
hrowell88
Feb 1, 2015 06:07 PM
turboblack2door
Jun 13, 2011 07:17 PM
spoolinNpullin
Dec 13, 2009 02:04 PM
H22Apowered
May 27, 2007 12:38 PM
