94-97 motor mount inserts
Old Oct 17, 2002 | 04:23 AM
dragaccord's Avatar
Default 94-97 motor mount inserts
does any one know why energy suspension only makes the insert for 1 torque positoin for the accord
Old Oct 17, 2002 | 04:25 AM
dragaccord's Avatar
Default Re: 94-97 motor mount inserts (dragaccord)
also does any one know where I can get the rear inserts
Old Oct 17, 2002 | 05:10 AM
Stew Pidasso's Avatar
http://store.summitracing.com/partdetail.asp?part=15922
This is the only listing I saw.
Old Oct 17, 2002 | 05:12 AM
SOHCArchangel's Avatar
Default Re: 94-97 motor mount inserts (Stew Pidasso)
there are no rear inserts because the ex rear mount is a power robbing part breaking excessive movement allowing POS
you need to get the rear mount and bracket off the same year lx/dx and get the prelude insert set for those two.
AND FOR THE LOVE OF GOD PLEASE USE THE SEARCH FEATURE NEXTTIME!!!!!!
[Modified by SOHCArchangel, 9:13 AM 10/17/2002]
Old Oct 17, 2002 | 08:36 AM
KTeller8's Avatar
Default Re: 94-97 motor mount inserts (SOHCArchangel)
ive got all the mounts from a 97+ lude if anyone needs them
Old Oct 17, 2002 | 08:39 AM
Nick M's Avatar
Default Re: 94-97 motor mount inserts (KTeller8)
Or you could just make your stock Ex rear mount solid. Fill with either fiberglass bondo or window weld.
Old Oct 17, 2002 | 08:46 AM
Default Re: 94-97 motor mount inserts (Nick M)
Does that window weld stuff dry to a hard fiberglass like finish or is it more of a silicone type consistency?
Old Oct 17, 2002 | 08:57 AM
urbanlegend21's Avatar
New User
Nick will that stuff hold up under track pressures?
Old Oct 17, 2002 | 12:00 PM
Nick M's Avatar
Default Re: 94-97 motor mount inserts (urbanlegend21)
I have fiberglass long strand bondo in my side and rear mount. I havent broken or cracked them yet. I got this tip from a muscle car guy who is a Honda mechanic where I did my swap. He saw my urethane front insert and told me about this apparently old trick of using fiberglass long strand bondo to strengthen mounts. They have withstood plenty of hard launches on the strip even lousy high rpms clutch dumps.
I know your question pertains to track use so my guess would be it would hold up just as well under track conditions as long as they were no worse than dumping the clutch in an H22 powered accord at about 6500rpm.
My suggestion would be to try the fiberglass bondo on the rear mount. Fill the rubber insert completely. Allow it to dry etc. I painted mine black after it dried. (Not that anyone can see it, but im a perfectionist ) Give it a try. Beat the poo out of it. If you do manage to break it it was only a $10 experiment. You could then go with the Lx/Dx/Lude combo mount and get the insert for it or even fill that one up with bondo. I am very confident though that my bondo filled mounts are as strong as urethane inserts.
Listen to me, I sound like a salesman lol.
Old Oct 17, 2002 | 01:25 PM
TypeSH's Avatar
are the saying that the prelude set of two includes the front mount which work w/ the front accord EX mount?
Old Oct 18, 2002 | 10:41 AM
dragaccord's Avatar
Default Re: 94-97 motor mount inserts (TypeSH)
I put the front inserts in and the whole car shakes like hell it is vibrating the srews out of my front bumper
Accord94DX's Avatar
lol. its rough but you get used to it.
Old Oct 18, 2002 | 09:41 PM
GimpyAccord's Avatar
Default Re: 94-97 motor mount inserts (Accord94DX)
I've heard of window weld long ago, but the bondo trick is new... not sure which i'd rather use when my time comes.
Old Oct 18, 2002 | 11:05 PM
Nick M's Avatar
I dont mind it pesonally. Everyone asks me "why is everything rattling and shaking?"
Gimpy- Its not just any bondo, its fiberglass long strand bondo
Old Oct 18, 2002 | 11:09 PM
FastechAccord's Avatar
I have just the front urethane insert and it is rough enough for my taste. The whole car shakes, especially bad with the a/c on.
Old Oct 18, 2002 | 11:26 PM
what would that normally be used for?? and is it at any normal bodyshop supply?
Old Oct 22, 2002 | 06:11 PM
m0t0rhead's Avatar
Default Re: 94-97 motor mount inserts (EvoAccord)
I notice it the most when the raditor fans turn on while the A/C is on.
If those fans turn off.. then the vibrations almost dissappear even WITH the A/C on. Weird.
I have noticed a nice difference in performance however. I wonder if i replace the rear mount and get the prelude insert if the vibration will be alot more.. or lessened. I'm assuming more.
Old Oct 22, 2002 | 06:31 PM
Nick M's Avatar
Default Re: 94-97 motor mount inserts (GimpyAccord)
Its used to repair fiberglass. Im sure a body shop would have it.
I did my prelude drivers side and rear mount with it. My front mount has a urethane insert.
hb_guy
May 8, 2007 06:06 PM
t . b o z
Aug 17, 2005 07:45 AM
Lemonade
Jul 31, 2002 12:05 AM
KF_S2000
Apr 1, 2002 07:13 PM
