Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR trans with 2000 SI shift linkage??
Old Sep 23, 2012 | 01:36 PM
bwfisherman09's Avatar
Default GSR trans with 2000 SI shift linkage??
i just bought a b16A2 with a GSR trans that has a 2000 Civic Si shift linkage.. Question is will this SI shift linkage bolt up in my 1994 civic LX that i am planning to put the motor in? i have looked around and the only think i have found is that people are using integra shift linkages.
But i need to know if the si linkage will work because the guy i bought the motor from said everything should be plug and play but after some research i am starting to develop some quiestions??
Old Sep 23, 2012 | 05:38 PM
eg6ajk's Avatar
Default Re: GSR trans with 2000 SI shift linkage??
Yes, 99-00 Si shift linkage is compatible, with 92-00 Civic and 94-01 Integra B-series motor/tranny swaps. Only one that is not compatible is Del Sol B16A linkage.
Old Sep 23, 2012 | 05:48 PM
Hell yeah thank you!! I have one more question..
I'm looking to get a short throw shifter and with the shift linkage being out of a 2000 SI do I get a short throw for a 2000 SI or for the car it's going in which is a 94 LX?
Old Sep 24, 2012 | 03:34 AM
eg6ajk's Avatar
You get a shifter for the linkage as it part of the assembly. But as a side note 94-01 integra 99-00 civic si shifter is interchangeable. D-series shifters are narrower and will have 1/2"play if used in b-series linkage, so do not do it.
Old Sep 24, 2012 | 06:29 AM
THANKS AGAIN
Old Oct 12, 2012 | 09:59 AM
hotbackem1's Avatar
sorry to bring this thread back up,
just wondering when you are talking about civic si are you talking about usdm si or canadian sir.. i have the same issue, gsr tranny in a ej hatch, i need a new shift linkage, not sure which one to order
Old Oct 12, 2012 | 10:21 AM
parts@synchrotech's Avatar
IIRC the Canadian 99-00 Civic SiR is the same as the USDM 99-00 Civic Si
Old Oct 12, 2012 | 05:05 PM
hotbackem1's Avatar
yes, im sorry i didnt make myself clear, i referenced them both together in my head, but what im unsure about is if they were talking about the usdm si, or canadian si, i dont know why i wrote sir, my apologies
Old Oct 12, 2012 | 05:35 PM
94EG8's Avatar
Seagull Management
They were referring to the USDM Si.
ElementzofR
Oct 3, 2012 05:08 AM
8Gomer9
Mid-Atlantic (Sales)
17
Aug 5, 2009 10:48 AM
Civic Type R 909
Jan 6, 2008 08:43 PM
johndilt
May 7, 2007 04:25 PM
GayHatch
14
Oct 24, 2003 10:50 AM
