HELP!! car not starting after wire tuck!!
Old Sep 23, 2012 | 10:25 AM
Jud-Boosts's Avatar
Icon3 HELP!! car not starting after wire tuck!!
Hi! I have a 90 EF sedan w/ a B18a1 (LS) swap from a 91 DA. I recently very carefully wire tucked it for Wekfest on the 30th of this month, I have 1 week to go and goin to start it I have nothing..Door and brake indicator on along w/ clock and radio acc. so it has power and I can hear the fuel pump but no crank. I dnt see the ECU light blinking either.... any common rookie mistakes u may know of or a standard check you may know of that I could walk thru would would b greatly appreciated... I took my time on the tuck and did everything 1 by 1 so i feel confident w/ my wiring...
Old Sep 23, 2012 | 10:45 AM
ef yu's Avatar
Default Re: HELP!! car not starting after wire tuck!!
how did you connect them together? butts connector? twist and tape? solder?
Old Sep 23, 2012 | 10:53 AM
crx_si-r's Avatar
How did you tuck the harness? Cut n extend? Did you convert to obd1? Did you remember to give power to the ecu?
Old Sep 23, 2012 | 11:01 AM
Jud-Boosts's Avatar
I carefully cut 1 by 1 on each harness that I labeled and extended via cut twist tight, solder and heat shrink...so i do feel confident w/ the wirng. wat do u mean give power to the ecu? i never disconnected the ecu tho... and the battery was out the whole time...after i finished the driver side i started it and everything worked, car cranked, all good....
Old Sep 23, 2012 | 11:02 AM
Jud-Boosts's Avatar
car and engine are both obd0
Old Sep 23, 2012 | 11:07 AM
mathewbyrne's Avatar
Have you checked the main fuses? And is your batt. Grounded correctly?
Old Sep 23, 2012 | 11:24 AM
Jud-Boosts's Avatar
I checked all the fuses and their all good....i made a very nice ground out of 4 gauge wire and have it bolted to strut bolt in which i sanded with 80 grit first... I ask about the ECU because I dnt see the little light coming on at all but then again like i said, i never even took out the ecu plugs :-/
Old Sep 23, 2012 | 11:48 AM
crx_si-r's Avatar
Is the thermostat ground on nice n tight
Old Sep 23, 2012 | 11:52 AM
Jud-Boosts's Avatar
yea, i had extended them and put em back on there nice n tight....it was 2 sets of double wire connectors correct? so four wires, 2 seemed to be grounds...i extended em all and put em back..
Old Sep 23, 2012 | 12:10 PM
Jud-Boosts's Avatar
wat exactly are those wires for? should the light on the ECU be coming on??
Old Sep 23, 2012 | 12:49 PM
crx_si-r's Avatar
Light should come one briefly. Then turn off. 2 are power grounds and the other 2 are logic grounds.
I did my tuck and it started right up, but then again I used one of my plug n play tuck harnesses that I made.
Old Sep 23, 2012 | 01:07 PM
Jud-Boosts's Avatar
i thought so...yea, i see no light flash at all which worries me. ok, but they do go together on the same bolt correct? cuz i unwraped the loomin and discovered it to be 2 seperate connectors, but i put em back w/ eachother on the same bolt.....yea, i wanted to buy a harness but i ve put all my money into getting ready for this show
Old Sep 23, 2012 | 01:10 PM
Rays91's Avatar
Looking for FEI contol module for a 91 civic hatchback. Car is not getting any spark.
Old Sep 23, 2012 | 01:12 PM
Jud-Boosts's Avatar
how would I know if its getting spark or not if it doesnt even crank....
Old Sep 23, 2012 | 01:14 PM
crx_si-r's Avatar
Rays91
Wrong section.
OP:
Yes they go to the same location on the thermostat housing
Old Sep 23, 2012 | 01:22 PM
Jud-Boosts's Avatar
ok then that is a check! how about the ground from the tranny/ clutch cable bracket to the frame rail?? i didnt put one back :-/
Old Sep 23, 2012 | 01:23 PM
crx_si-r's Avatar
Fix it. That is what also grounds the battery to the motor/frame.
Old Sep 23, 2012 | 01:25 PM
Jud-Boosts's Avatar
ok im on it! i ll b back in 10min. n dude seriously...thank you so much for responding and helping!
Old Sep 23, 2012 | 01:38 PM
Jud-Boosts's Avatar
ok for sure that helped! lights are brighter, ck engine flashes on now...but still no crank ....
Old Sep 23, 2012 | 01:41 PM
crx_si-r's Avatar
Did the car start up fine before the tuck?
Old Sep 23, 2012 | 01:43 PM
Jud-Boosts's Avatar
hell yea, it was my daily...and after i did the driver side harness it started fine and everything worked
Old Sep 23, 2012 | 01:53 PM
crx_si-r's Avatar
Fuse box under the dash right
Old Sep 23, 2012 | 01:55 PM
Jud-Boosts's Avatar
yea and all fuses show to be good
Old Sep 23, 2012 | 02:01 PM
crx_si-r's Avatar
No check engine lights
Old Sep 23, 2012 | 02:05 PM
Jud-Boosts's Avatar
nope, evry once in a while wen i nail it or ride it hard it would come on but go off later or after turn off
