HELP!!! Squeaking noise from engine bay!!
Old Oct 17, 2002 | 12:56 AM
d0nkeyxPunch's Avatar
Banned
Default HELP!!! Squeaking noise from engine bay!!
Hey whats up guys. I really need your help. I hear an annoying squeaking noise in my engine bay. It sounds like its comming from under the intake manifold, but I am not positively sure. I tried to look under it but I couldn't really see anything that might make that noise. If ANYONE has any idea or can help me, that would be extremely appreciated. Thanks in advance.
Old Oct 17, 2002 | 01:06 AM
RR98DX's Avatar
Default Re: HELP!!! Squeaking noise from engine bay!! (FastxCivic)
check ur belts
Old Oct 17, 2002 | 01:14 AM
Banned
Default Re: HELP!!! Squeaking noise from engine bay!! (RR98DX)
belts as in which one? I replaced my timing belt about 20K miles ago
Old Oct 17, 2002 | 05:50 AM
lagger's Avatar
check the alternator, power steering, and ac belts(if you have ac). if it's coming from behind/under the intake manifold, it's probably the alternator if it is a belt. just press on them a little bit and see if there is a lot of slack, there shouldn't be much.
Old Oct 17, 2002 | 06:47 AM
E. Honda's Avatar
Default Re: HELP!!! Squeaking noise from engine bay!! (lagger)
Does it happen only when driving? check you hood, mine was squeeking when I went over bumps, I just put some wd40 on the latch.
Old Oct 17, 2002 | 11:22 AM
Banned
Default Re: HELP!!! Squeaking noise from engine bay!! (VSM SiR)
It happens when my car is stopped and its idling. It makes *squeaky squeaky* and pause then goes again. I tried hitting the intake manifold and whenever i did it, there was a squeaking noise.
Old Oct 17, 2002 | 12:22 PM
ejprimo's Avatar
its prob. one of the three belts mention above.
Old Oct 17, 2002 | 12:38 PM
intezn's Avatar
Default Re: HELP!!! Squeaking noise from engine bay!! (ejprimo)
my car does that also, it does it only when i just started up the car? and after a while like few seconds, it will go away? i changed the belts a while ago, what's wrong with them, why is it making nosie? too tight?
Old Oct 17, 2002 | 12:40 PM
KEVlN's Avatar
New User
Default Re: HELP!!! Squeaking noise from engine bay!! (intezn)
Yah mind does that. And sometimes mine will do it more when it is raining. I am almost certain it is a belt, but which one?
Old Oct 17, 2002 | 07:24 PM
ejprimo's Avatar
Default Re: HELP!!! Squeaking noise from engine bay!! (Civic95)
whenever i hear the squeaking sound from under the hood, i tighten the alternator belt and it goes away.
[Modified by ejprimo, 8:25 PM 10/17/2002]
Old Oct 17, 2002 | 08:42 PM
Evs-One's Avatar
Solbros Owns Me
Becaus when you first start up your car, the belts and pulleys are cold. After a short while, the belt/pulley heats up and lets the belt grip better, that's why it goes away. Tighten your alternator belt. All it takes is a 12mm wrench- I use a jack handle or hammer handle to push against it to tighten the belt.
Old Oct 18, 2002 | 01:59 AM
Banned
Default Re: HELP!!! Squeaking noise from engine bay!! (Emerica)
My car makes the squeaking noise when its in idle. Yes it is a 5 speed. Can it be that my motor mounts could be a little lose?
Old Oct 18, 2002 | 02:46 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Your answer is more then likely already listed, please read above.
JasonYo
26
Oct 29, 2022 11:44 AM
De_tour
Jan 3, 2006 05:53 PM
crxtreme27
May 11, 2005 09:05 PM
pbizzlegsr
Mar 1, 2004 05:09 PM
91sihatchback
Jun 30, 2003 12:20 PM
