HELP!!! Squeaking noise from engine bay!!
Banned
Hey whats up guys. I really need your help. I hear an annoying squeaking noise in my engine bay. It sounds like its comming from under the intake manifold, but I am not positively sure. I tried to look under it but I couldn't really see anything that might make that noise. If ANYONE has any idea or can help me, that would be extremely appreciated. Thanks in advance.
Banned
Re: HELP!!! Squeaking noise from engine bay!! (RR98DX)
belts as in which one? I replaced my timing belt about 20K miles ago
Re: HELP!!! Squeaking noise from engine bay!! (FastxCivic)
check the alternator, power steering, and ac belts(if you have ac). if it's coming from behind/under the intake manifold, it's probably the alternator if it is a belt. just press on them a little bit and see if there is a lot of slack, there shouldn't be much.
Banned
Re: HELP!!! Squeaking noise from engine bay!! (VSM SiR)
It happens when my car is stopped and its idling. It makes *squeaky squeaky* and pause then goes again. I tried hitting the intake manifold and whenever i did it, there was a squeaking noise.
Re: HELP!!! Squeaking noise from engine bay!! (ejprimo)
my car does that also, it does it only when i just started up the car? and after a while like few seconds, it will go away? i changed the belts a while ago, what's wrong with them, why is it making nosie? too tight?
New User
Re: HELP!!! Squeaking noise from engine bay!! (intezn)
Re: HELP!!! Squeaking noise from engine bay!! (Civic95)
whenever i hear the squeaking sound from under the hood, i tighten the alternator belt and it goes away.
[Modified by ejprimo, 8:25 PM 10/17/2002]
Solbros Owns Me
Yah mind does that. And sometimes mine will do it more when it is raining. I am almost certain it is a belt, but which one?
Banned
Re: HELP!!! Squeaking noise from engine bay!! (Emerica)
My car makes the squeaking noise when its in idle. Yes it is a 5 speed. Can it be that my motor mounts could be a little lose?
Location: Why so you can pretend like youre interested, FL/OK
JasonYo
26
10-29-2022 11:44 AM
