Wrong axle question?
I have a 92 hatch with a B16 swap, I have had a lot of play in the passenger axle since i bought it. I havent driven it more than a tank of gas since. I am wondering if the wrong (d series axle) would even fit and function with a b-series motor. I am thinking the previous owner just put the d series axles in when doing the swap and that is causing my issue. I have already replaced the axle seals on both sides and restabbed them to make sure that was not the issue.
Really just want to know if swapping to the 99-2000 Si axles will correct my issus and if the will fit correctly with the 92 hatch hub assembly
Thanks
Thanks
'99 - '00 Si axles fit fine, but without actually seeing the problem I couldn't tell if your current axle is causing your problem or not. '94 - '01 Integra axles and '94 - '97 Del Sol VTEC axles will also work.
ok thanks, There is just a quite a bit of play in the axle where you can turn it forward or back, almost like when you have a socket to big for the nut. Still holds but just not the right way. transmission shifts with no issues and there is no play or funny jolting while moving just more or less when you touch it by hand.
Thanks again.
Thanks again.
eggsi619
Oct 13, 2022 02:57 PM
