b20b boost
anybody got a tried and true set up for around 375hp out of a modest built b20b? i am looking at spending around 2k on the actual engine but im not super familiar with boosting b series so i dont know what runs well together.
well i have looked at going brian crower all the way with bc rods pistons cams and i already have bc springs, valves, retainers. i am looking at using the bc stage 3 forced induction cams and bc I-beam rods
We ve done alot of stock b20v turbos in the 400
It's a way of trying to make out there's something special about the way you tune and some how (magically) you can make a stock block as reliable as a built block.
Tuners do it over here to, I find it very annoying. When the bottom end fails they just blame it on something else and back it up with a load of BS. Well, that's always what I've made of it anyway.... People naturally want to save money, so if they know a guy with a "wand" that tells them they don't need to build their block then the cash is his....
If a mechanical part has been pushed beyond its limit then its going to fail sooner or later. There is nothing what the tune can do to save it....
Miracle tunes. I tuned one on my sohc only headstuds 13.5psi 3.5yrs daily driven. But im intested in specs of the cracked sleeves. Power/boost/turbo/rpms/ anything really. Currently running a 50trim, b20, 4.78fd, 93cx. No lack of low-end fun.
but if a shop is doing it on there own cars and u see then racing the **** outta it
hatchattak
Nov 25, 2003 06:43 AM
