Questions about swapping a d15b2 in place of a d15b1
Old Sep 20, 2012 | 06:25 PM
WinstonSmith's Avatar
Default Questions about swapping a d15b2 in place of a d15b1
I was just sold a d15b2 (dual point)motor/5speed from a crx to replace the d15b1 and 4 speed in my 91 ef civic. I have a multi-point head sitting in my garage that i would like to swap over also.
Is there anything that I should worry about before I make this swap over. Is this a direct swap over? Will this be a direct swap?
Any help would be greatly appreciated.
Thank you very much.
Old Sep 20, 2012 | 07:25 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Questions about swapping a d15b2 in place of a d15b1
Heads are all the same, difference is in the camshaft and springs. Everything is a direct swap but you have to make sure that if you use the A6 camshaft in a 1.5 block you use the Y7/8 gear or adjustable cam gear.
Old Sep 20, 2012 | 07:45 PM
I think I'm going to just swap the whole motor over. I was informed that I can get better gas mileage and performance after going to the d15b2 with the the multi point swap.
Old Sep 21, 2012 | 01:40 PM
24TEN's Avatar
PHANTOM MENACE
If there's nothing wrong with your current B1, it'd be easier to just swap the camshaft out and do the MPFI.
Old Sep 22, 2012 | 02:34 PM
maiden424's Avatar
I'm doin the same swap only staying with the pgmfi set-up.. So I need a pm5 ecu? What about my std wiring same distributor & wire harness as the dx right? Only change is the ecu right? Any input is appreciated..
Old Sep 22, 2012 | 03:00 PM
maiden424's Avatar
Of course I'm not gonna mess with cams & such.. I just want a bit more hp so I can get up a damn hill..
Old Sep 22, 2012 | 05:43 PM
BIGef's Avatar
yes everything is a direct swap.
i agree with 24ten everything is the same. id rather swap camshaft and do the mpfi swap.
basically your doing the samething just swapping in the b2.
Old Sep 22, 2012 | 07:56 PM
Ok, I know this will be a silly question but is there a write up on swapping out the cam? And possibly the MPFI swap? Thank you very much.
Old Sep 23, 2012 | 06:03 AM
KINGVEM^^ED6's Avatar
Google mpfi swap its been done a million times
Old Sep 24, 2012 | 07:29 PM
maiden424's Avatar
I'm just trying to keep it simple.. I'm going remanufactured long block but I want the extra hp.. I'm looking at quite a bit already.. Anybody know of any reasonable places that sell reman motors?
Old Sep 24, 2012 | 07:32 PM
maiden424's Avatar
Also reputable..
Newguy1995
Aug 26, 2018 02:29 AM
morecoffeeplzz
Jul 3, 2017 07:16 PM
kimmiey
Apr 29, 2007 07:23 AM
93gsrhatchbrid
Apr 22, 2006 10:01 AM
