speed sensor issue..
Old Sep 19, 2012 | 07:58 PM
GabesEF909's Avatar
Default speed sensor issue..
hello HT im having a problem my speedometer and mileage dont work on my cluster and i was wondering what i need to do to fix it im wondering if the speed censor isnt connected and where is it? my car has a d16a6 odb1 p28 ecu..
any ideas.. thank you
Old Sep 19, 2012 | 08:02 PM
BIGef's Avatar
Default Re: speed sensor issue..
connected back of your cluster to to the transmission
Old Sep 19, 2012 | 08:10 PM
DDream's Avatar
i just fixed mine this is all i needed.... your might be different
have you checked behind you cluster and make sure its clipped? is your cable screwed up? have you checked where the cable goes to tranny?
http://www.hondapartsunlimited.com/p...689-000-honda/
Old Sep 19, 2012 | 08:13 PM
GabesEF909's Avatar
which one is it behind the cluster and where does it connect to the trans in the back closer to the wall or on the sides?
Old Sep 19, 2012 | 09:12 PM
BIGef's Avatar
the cable is closest to the firewall.
the cluster its the only black fat cable.
Old Sep 23, 2012 | 08:45 PM
GabesEF909's Avatar
Thank you ima check it out tomorrow
Old Sep 24, 2012 | 09:16 AM
GPC91's Avatar
sorry not trying to thread jack here but you said check behind your cluster and make sure its clipped. i know that there is a clip on the trans side but where does the clip go on the cluster side?
lopezchris21
Sep 18, 2008 11:40 AM
crxtreme27
Jan 19, 2005 05:48 PM
cutt
Nov 12, 2004 06:57 PM
team2n1hatch
Apr 24, 2003 05:07 PM
Babybluegsr92
Sep 1, 2001 11:21 PM
