What kind of spindles needed for LS swap ?
Old Sep 19, 2012 | 06:49 PM
cn_bb's Avatar
Default What kind of spindles needed for LS swap ?
Just done with an LS swapped, it runs good now with LS axles in but sometimes I can hear the strange sound when it spinning ( actually on the passenger side ).
Being told by some people that I have to replace the spindles and hubs to make it good, is it true ? Can anyone verify ?
Thanks,
D
Old Sep 19, 2012 | 08:57 PM
4drEF's Avatar
Keyboard Humorist
Default Re: What kind of spindles needed for LS swap ?
What is the sound?
You don't need different knuckles or hubs.
All 88~91 Civic/CRX knuckles work perfect with the exception that you need to remove the dust ring so the asle doesn't bind.
What sort of sound are you hearing?
Do you know how to check your wheel bearings?
Old Sep 19, 2012 | 09:06 PM
Mr.Cheezil's Avatar
i believe standard and HF knuckles are to small for LS axles.
Old Sep 20, 2012 | 01:27 AM
TeamRedline89Hatch's Avatar
Correct. I own a std and my brother has an hf. We both had to upgrade knuckles for our swaps. dx/si are just fine.
Old Sep 20, 2012 | 07:50 AM
4drEF's Avatar
Keyboard Humorist
No sense in pointing out the irrelevant.
OP says he has it running and it's making noise.
They aren't saying "Why won't my axle fit into my hub?"
Old Sep 20, 2012 | 08:35 AM
Hope you figure it out.
Old Sep 20, 2012 | 09:18 AM
theEFkid's Avatar
how are the wheel bearings? you stated you hear the noise when its spinning. as 4drEF said the knuckles from 88-91 work with the exception of the STD and HF. i would check the wheel bearing and make sure everything is tight and installed correctly
Old Sep 20, 2012 | 09:44 AM
4drEF's Avatar
Keyboard Humorist
I actually didn't say the exception.... and got corrected.
CN_BB - another thought; is your car lowered and what mount kit did you use?
If you are low then it is possible that new angle of your axles is causing issues.
Some mount kits sit the engine well enough that it's typically not a problem, however there are plenty of kits that don't sit the motor well and you run into this type of problem.
Old Sep 20, 2012 | 10:13 AM
DCRB's Avatar
op did you remove the dust caps on the knuckles when you installed your axles? if not the axles will bind up and rub on them.
Old Sep 20, 2012 | 10:56 AM
cn_bb's Avatar
Thanks for all concering guys !
I just have a tech guy checked and he said everything is good including : axles, hub, wheel bearing, etc...and the noise is comming from the tranny.
I will do some more check/search to see ..
thanks,
D
bubba3369
Aug 30, 2009 06:41 PM
showcivic2001
Jun 25, 2008 10:26 AM
jdmDRIFTER
Mar 8, 2007 11:59 PM
crxsteve
Aug 12, 2006 09:31 PM
hooddub
Mar 7, 2006 07:51 PM
