Hey Brodudes, is this part need?!? (PICS)
hey i replaced everything on my timing side, belts, etc. including the tensioner we do not speak of.
to get this on, i will need to remove EVERYTHING to install it. i dont know the exact name, and i dont know exactly what it does. it was not in any of the chilton diagrams. the mechanic who was overseeing the work said he doesnt think it does anything important but hes not certain.
HAYeLP
this was the old part that i replaced.
what is its exact purpose? to just hold the timing cover on? this is the bolt that has a rubber seal on it as well as a pin.
HAYeLP
What tensioner did you install? H22 Auto tensioner? Or Kaizenspeed H series manual tensioner.
Edit: Forgot this was you: Is the H22 Auto tensioner hyped up?
In that case, yes. Re-do it and replace the auto tensioner with a manual tensioner from an H23.
http://mr22.tistory.com/tag/tensioner
The auto-tensioner WILL fail. Doesn't matter if it's brand new. Unless you are willing to risk rebuilding your head. Then, by all means...leave the auto-tensioner in there.
Either way, you need to take it apart again. Either to install that bolt or replace with manual tensioner.
Regardless, you NEED that bolt for the auto-tensioner.
Kaizenspeed also makes a manual tensioner. That alone should convince you that the auto tensioner has known issues, if you haven't searched about them failing already.KS Tuned - H series manual tensioner
yes, i used the auto tensioner.
are u positive that i need that bolt? what exactly is its role?. i thought it was just there to help hold the timing cover on. its the bolt that sticks outside of the timing cover and u have to remove a pin and rubber seal off of the the bolt to take off the cover.
im really not trying to remove my timing belts, EVERYTHING including trying to compress the tensioner if i dont have to.
that would really suck
no more replies about the auto T. , i want to figure out what that bolt is used for and if i need to take everything back off and install it.
need to know, because im going to probably turn the engine tonight once i install the distributor and vtec solenoid.
mechanic friend said that the bolt is only there to help with replacing timing belts. so its not needed, its just there to help lock the tension into place so removing the belts is easier.
And you understand what there trying to explain to that is a common problem which is why they are saying to switch. They know its a problem thats why the later verison motors built by honda's are chains and have a completely different way of tenisioning on things.
i think you should put the bolt back before have a serious issue later on.
im just going to use the auto tensioner. and the mechanic even asked the other people at his shop and they all said that the bolt isnt needed, it just helps when replacing/removing the timing belt. hes done 1000s of timing belt replacements and he was a mechanic instructor in the army for over 4 years so im just guna go with what he says for now.
good luck hope it all goes well for you then. FYI a deuce in a half and humvees aren't the same as a regular car. This is coming from a guy that flew and maintained uh-60's and did that motor pool stuff every freaking Thursday.
and hes been a certified mechanic for over 15 years as well as being a mechanic for the army so im just guna go with what he says. thats a long time to be a mechanic and thats a lot of time to stick with an opinion on something. but liek i said well see, if i get money saved up again and decide to build the head then ill definately look into getting a manual tensioner swap. for now im just going to leave it be
You should see if he'll warranty his work. Doubtful since it seems like it was a joint effort for the job but you may want to look into it.
Good luck though!
Good luck though!
naa to be honest im not too worried about it, id say SLIGHTLY hesitant just because of the things ive been hearing about it but its whatever.
That bolt is used for properly tightening the balance shaft belt. When you tighten it adjusts the tension on the timing belt by lifting up that little arm that the autotensioner presses up on. It's also used when taking the belts off I believe to release some of the tension
If that bolt is missing then you can assume that the mechanic didn't go through the proper belt tightening procedure, because in the manual it describes using that bolt.
The hole on the end is for a cotter pin or something like that i believe to hold the cover on.
About the tensioner... I used the KS tensioner myself, but there has been a lot of bad rep for the autotensioner. I would say that if you're pushing you're engine at all, you should go with a more solid tensioner setup such as the KS or the H23 setup. If you're stock, just using the car for normal purposes, I would say you would probably be okay with the auto, but make absolutely sure you install and tension it correctly, or else you could be looking at some damage to your engine.
I just finished replacing the timing belt on my car last night. That bolt there to hold the tensioner in place if you are re-using the timing belt. You loosen it until the beveled side comes in contact with the tensioner assembly and it holds it in place when you take the belt off.
If it's not holding anything else on there (I don't think it does) then you should be fine.
PS. I used a new auto-tensioner on mine as well.
I just finished replacing the timing belt on my car last night. That bolt there to hold the tensioner in place if you are re-using the timing belt. You loosen it until the beveled side comes in contact with the tensioner assembly and it holds it in place when you take the bolt off.
For future reference, if you have the tensioner off, REPLACE IT WITH AN MANUAL TENSIONER. I know you already used the Auto, but there is really no excuse if you have to buy a new tensioner.
mikegeezy
Mar 29, 2006 05:23 PM
