Honda CR-V & Element 2WD & 4WD Element & CR-V
Car won't start
Old Sep 17, 2012 | 01:05 PM
mariposa921's Avatar
Default Car won't start
I've replaced plugs, battery, distributor and timing belt and car still won't start. What do I try next?
Old Sep 17, 2012 | 03:38 PM
LDForget's Avatar
Default Re: Car won't start
try a hammer?
What are the symptoms? cranks but no start? doesnt crank at all? check engine light? did you check the code if so? do you have spark? are you sure? are there any specific smells? did you do a compression test? does it start, then quit working after a few minutes?
Old Sep 18, 2012 | 04:31 PM
HNDA_4SHOOR's Avatar
wow
nate10498
14
Jan 18, 2009 08:56 PM
juanb
Aug 24, 2004 06:50 PM
b18c1eg2
Aug 21, 2004 12:28 AM
Kusai.Nihonjin.Desu
Aug 28, 2003 12:49 PM
DSC
Mar 31, 2002 08:05 AM
