B18b1 fan cooling issues-won't turn on
Old Sep 16, 2012 | 04:58 PM
joshd_bh's Avatar
Default B18b1 fan cooling issues-won't turn on
Hi I did a 96 ls swap and extended the wires for the thermostat sensor over to the thermostat housing. The fan won't turn on. I turned the air on full and pushed the ac button, and still nothing. I bought a new acura genuine sensor, and still no fan. What could be wrong??
Old Sep 16, 2012 | 05:39 PM
joshd_bh's Avatar
Default Re: B18b1 fan cooling issues-won't trun on.
I just checked my fuses. #15 which is the cooling fan is good. It's also the correct ampage. Please I need help!
Old Sep 16, 2012 | 05:43 PM
Former User's Avatar
Does the fan run if you jump the switch connector?
Old Sep 16, 2012 | 07:11 PM
M-benz's Avatar
Jump the fan directly to the battery see if it works ? If it does, check the relay near the passenger head light ( it hanging on the fender)
Old Sep 16, 2012 | 07:22 PM
joshd_bh's Avatar
To jump the fan, do I just attach a wire from the red to the red, and the black to the black? And how do I check the relay? I pulled it off and the pigtail was fill of this gel stuff which is supposed to help conduct.
Old Sep 17, 2012 | 05:59 AM
M-benz's Avatar
Yes. For a quick test , I will just go to autozone and buy the new one bring it home and plug in . If it works u know the problem if not return it .
Old Sep 17, 2012 | 06:39 PM
joshd_bh's Avatar
Alright, I tested the fan and relay, they both work... The fuse is fine and the sensor for my thermostat housing is brand new and an acura genuine part. What next?? It's also worth noting that there is no thermostat, because it wouldn't open. I put it in a bioling pot of water, and it opened. Should I put it back in? I think that there was a bubble in the way..
Old Sep 17, 2012 | 08:28 PM
joshd_bh's Avatar
Ok, I put the thermostat back in, and still the water wont flow. I drove it softly and the heat never got too hot. The lower radiator hose is pretty hot, but the lower isn't at all.
Old Sep 18, 2012 | 05:51 AM
Nooch's Avatar
... I think you wrote that wrong but....
You're car shouldn't be getting hot/overheating. It should get just under the halfway mark. Burp the cooling system (google it if you need help)
I've seen issues with air in the system causing the fan not to turn on
Old Sep 18, 2012 | 06:06 AM
BIGef's Avatar
bleed your car
Old Sep 18, 2012 | 11:02 AM
joshd_bh's Avatar
I ran it yesturday and the car didn't get too hot, but I couldn't get the air out of the way. Also 96 B18B1's don't have a coolant bleeding screw.
Old Sep 18, 2012 | 11:06 AM
Bleed like this:
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Sep 18, 2012 | 07:58 PM
joshd_bh's Avatar
"Start the engine and let it run until it warms up (the radiator fan comes on at least twice)." The fan doesn't come on at all!!
I'm not trying to bleed it. I'm trying to get the thermostat to open and the fans to turn on.
Old Sep 18, 2012 | 08:17 PM
Air in the system could prevent the switch from activating.
And you haven't answered this question:
Old Sep 19, 2012 | 04:58 AM
joshd_bh's Avatar
Yes the fan works. I've also checked the relay and it works too.
Old Sep 19, 2012 | 04:59 AM
This^ answers a different question than mine, which is:
Old Sep 19, 2012 | 05:33 PM
joshd_bh's Avatar
Do you mean the sensor that either goes on the back of the block or in the thermostat housing?
Old Sep 19, 2012 | 05:35 PM
The one on the thermostat housing, which is where the fan switch is located on the B18B1 engine.
Old Sep 19, 2012 | 06:52 PM
joshd_bh's Avatar
Ok, how do I jump that? Do I put power to the pigtail that connects? I just replaced that ECT switch with a brand new genuine acura one. There shouldn't be anything wrong with it.
Old Sep 19, 2012 | 06:57 PM
Unplug the fan switch connector and then use a paperclip or piece of wire to short the two terminals in the 2P connector. When the key is turned to ON(II), the fan should run.
Old Sep 20, 2012 | 05:22 PM
joshd_bh's Avatar
Default Re: B18b1 fan cooling issues-won't turn on
Yeah I jumped it with a paper clip and the fan ran. Now what?
Old Sep 20, 2012 | 05:25 PM
The fan circuit is fine. Bleed the cooling system -- see post #12.
Old Sep 20, 2012 | 07:41 PM
joshd_bh's Avatar
Awesome thanks! My other problem is that I can't get the thermostat to open when installed. I put it in a hot pot of water and it opened. Is it just not hot enough? I can't tell the engine temp so I dont want to overheat the engine trying to open the thermostat.
Old Sep 20, 2012 | 07:46 PM
Same answer - bleed the cooling system.
Old Sep 21, 2012 | 12:37 PM
joshd_bh's Avatar
Aright ill try that. Now I have another problem. When I pulled out the thermostat to test it, and then put it back in, the car ran pretty bad. I thought I had a blown head gasket, but my car didn't smoke at all when I started it, and smells like fresh gas. What would cause this? I think its misfiring.
