Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help!!!
Old Sep 16, 2012 | 11:36 AM
Enkriss's Avatar
Default Need help!!!
My ISB is toast so while i have the trans open figure I would give it a good look over and replace all the bearings...
Well i took the differential out of the case and noticed the diff pin wiggles back and forth. Is this normal?
Its a D17a2 2004 civic ex.....my commuter car.
Old Sep 18, 2012 | 07:14 PM
Enkriss's Avatar
Default Re: Need help!!!
Anyone?....
Old Sep 19, 2012 | 06:17 AM
David @ Synchrotech's Avatar
It is normal for the diff pin to move a little. It can wear from one tire spinning in the snow or from racing but this is not usually an issue on the D17 Civic. However, if the spider gears show signs of wear you should replace the diff.
Adam Denick
Honda Civic (2006 - 2015)
Nov 23, 2015 09:34 AM
murph78
Aug 19, 2013 11:56 AM
89sir-9
Dec 14, 2001 01:44 PM
