91 civic dx, takes forever for headlights to come on in winter
Old Sep 16, 2012 | 05:35 AM
wasp9166's Avatar
Default 91 civic dx, takes forever for headlights to come on in winter
anyone experienced this? i'm baffled, they work fine in summer , but the colder it is out, the longer they take to light up after turning them on, sometimes 10 minutes if it's super cold, been like this for years and i'm tired of it
i'm stumped as to why
my suspicion, is, much like the main relay when it's hot, which i all ready solved
it's the switch acting same way when cold?
Old Sep 16, 2012 | 09:48 AM
Former User's Avatar
Default Re: 91 civic dx, takes forever for headlights to come on in winter
Do you have the same problem with the taillights?
Have you cleaned the switch contacts and the headlight ground wires in the engine bay?
Old Sep 16, 2012 | 01:35 PM
wasp9166's Avatar
no problem with tails
no idea where switch contacts are, on the steering post ya mean?
and no idea where headlights grounds are, but i don't have the problem in the summer, so i can't see how it would be a grounding issue,then again if it was the switch would it effect tails or are they a separate post off switch
if most here say it's the switch, would i need anything other than #11?
http://www.hondaautomotiveparts.com/...INATION+SWITCH
and does it have to be oe? i see some smp ones on ebay for about $15 cheaper
Old Sep 16, 2012 | 01:42 PM
Look in the 92-00 Civic FAQs sticky. Danomatic93 has a thread on disassembling the light switch and cleaning the contacts.
Do the same for the headlight ground wires (G201, G301, G401) in the engine bay.
Do the high beams work properly?
Old Sep 16, 2012 | 02:16 PM
wasp9166's Avatar
yes, when they eventually turn on everything is normal
if this a contact issue, why would it only happen when it's cold out?
the colder it is , the longer it takes
Old Sep 16, 2012 | 02:19 PM
What I was asking is: Do the high beams have the same problem as the low beams?
Why not?
Clean the switch contact points and the ground wires and then go from there.
Old Sep 16, 2012 | 02:22 PM
wasp9166's Avatar
no
Why not?
i can't seem to find that post, and i have no idea where the 3 grounds are, pics anywhere ?
i just remembered, no, i can use the high beams, until lows turn on, sometimes it's miles from my house early in morning on cold morning, so it's only lows that have the issue
Old Sep 16, 2012 | 02:24 PM
Switch -- Did you look in the electrical section in the FAQs sticky of the 92-00 Civic forum?
Old Sep 16, 2012 | 02:27 PM
wasp9166's Avatar
yep, didn't see anything in exterior lighting
Old Sep 16, 2012 | 02:34 PM
i. Wipers, Turn Signals, Combination/Wiper Switch, Dome/Map Light, Trunk light, and Chime
Old Sep 16, 2012 | 02:40 PM
wasp9166's Avatar
ok, found the post, meh, i'd rather just buy a new one if that's what it is
so why would high beams not be effected ya think?
Old Sep 16, 2012 | 02:42 PM
Haha...so lazy
AGAIN, because the contact inside the switch is corroded.
Old Sep 16, 2012 | 03:00 PM
wasp9166's Avatar
i'm far from lazy, just got done doing timing belt, rocker gaskets etc
just can't be bothered right now
my intermittent wipers also have their own mind tho they do work, i assume it's same issue
i'm still stumped as to why corrosion would only be a cold issue, but i''ll clean or replace switch
Old Sep 17, 2012 | 03:25 PM
wasp9166's Avatar
welp, took it apart today and cleaned it with maf cleaner
see what happens in morning
Old Sep 18, 2012 | 01:11 PM
wasp9166's Avatar
well, that did nothing
Old Sep 18, 2012 | 02:14 PM
ONLY when the problem happens:
1) Unplug the light switch and measure voltage to body ground at the two white wire terminals in the switch connector.
2) Reconnect the switch, turn the headlights on, measure voltage to body ground at fuses 10 and 11.
3) Unplug the headlight connectors, turn the headlight switch on, and measure voltage to body ground at the Red/Yel or Red/Wht wire terminal in the plugs.
Old Sep 23, 2012 | 08:10 AM
wasp9166's Avatar
well, i ordered a new switch and will go from there
i should have said, another thing this car does along the same lines
the colder it is out the longer it takes to go into park
i can actually put it in park but i have to wait for the red box to light up around the p before i can turn it off and remove key
the colder it is, the longer i have to wait
Old Sep 23, 2012 | 09:35 AM
See post #16. Doing those diagnostic tests with a multimeter will keep you from throwing parts at the problem.
Old Sep 23, 2012 | 09:42 AM
wasp9166's Avatar
yes, i was gonna go there after eliminating switch
i dunno, way i do things i guess, i like to eliminate things one at a time
switch was pretty worn inside looked to me , figured couldn't hurt
i will test white wires in plug before installing new one
Old Sep 23, 2012 | 09:49 AM
The switch can also easily be Ohm tested with a multimeter.
Old Sep 23, 2012 | 10:16 AM
wasp9166's Avatar
i know, don't guess troubleshoot
what should voltage be at those 3 areas you listed?
the problem is, this only happens early in the morn right now, when it's cold, and also dark ,lol
only reason i put it off
Old Sep 23, 2012 | 10:18 AM
Within a volt of the voltage measured across the two battery posts.
Old Sep 23, 2012 | 10:20 AM
wasp9166's Avatar
and that should be 12?
Old Sep 23, 2012 | 10:23 AM
Battery voltage = whatever voltage is measured across the two battery posts -- the normal range is 12.5-13V.
Old Sep 23, 2012 | 11:09 AM
wasp9166's Avatar
i know i have to do it when they aren't coming on, i'll have to get up early one morning
but i wanted to get a few numbers now
batt is 12.3 v and 14.5 engine running
light connectors are both 11.5 as are both fuses
