Suspension & Brakes Theory, alignment, spring rates....
Bouncy Ride
Old Sep 15, 2012 | 10:32 PM
BKJJ77's Avatar
Default Bouncy Ride
I have my car lowered on KYB AGXs with eibach Ground Control
Its just recently started being really bounce after i lowered the back more
I know that its bouncy because i am bottoming out my strut...my question is, if i get extended top hats will that leave more room for my strut so its not all only on the spring and therfore stop my ride from bouncing so much...also what kind of extended top hats should i get...Thanks
Old Sep 16, 2012 | 03:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Bouncy Ride
Sounds like your shocks are blown. AGXs really don't stand up to lowering. Top hats won't fix the bounciness.
Old Sep 16, 2012 | 09:05 AM
BKJJ77's Avatar
if i raise the back a little the bouncnyness goes away so i know they arent blown
Old Sep 16, 2012 | 09:09 AM
alphalanos's Avatar
like marc said those shocks are not meant to be very low. i had them and they blew out in a year. extended top hats may help a little but it is not the solution. you need a high performance shock meant for higher spring rate. what rate ground controls do you have. you can go with koni yellow if your rates are less than 550 or so.
Old Sep 16, 2012 | 09:35 AM
The Grumpiest
Patient: Doc. It hurts when I do this.
Doctor: Then don't do that.
See above post. Even a mild drop is pushing those KYBs.
Old Sep 16, 2012 | 12:05 PM
BKJJ77's Avatar
thats how my car came...so ur say i should get some koni yellows
Old Sep 16, 2012 | 12:26 PM
The Grumpiest
Originally Posted by alphalanos
what rate ground controls do you have?
Old Sep 16, 2012 | 03:49 PM
FlewByU352's Avatar
Couldn't a bouncy ride be from both under dampened or over dampened? I'm having a serious issue right now with that. This one bridge is super bumpy for damn near every car even stock! I can't tell if it's packing up or rebounding too fast but it is very harsh to drive on. Should I just keep making laps and adjusting?
Old Sep 16, 2012 | 05:19 PM
The Grumpiest
I guess if you're talking about mismatched shock/spring/ride height combo. I'll let someone better versed in brake tech answer.
Old Sep 16, 2012 | 08:42 PM
98civdx's Avatar
Master Detailer
Spring rates, and how low are you?
Old Sep 16, 2012 | 11:02 PM
BKJJ77's Avatar
can i just get a simple yes or no if extended top hats will do anything
Old Sep 17, 2012 | 08:39 AM
98civdx's Avatar
Master Detailer
If you would read, you would see that question has alreay been answered.
Old Sep 17, 2012 | 08:48 AM
TunerN00b's Avatar
Bouncy and harsh are opposing conditions. It isn't really possible for a car to suffer from both at different times, without something seriously wrong with the car.
Bouncy is under damped. Harsh is over damped.
Under damped is caused by an inadequate amount of shock for the spring rates. If you're too low, and the bumpstops come into play under suspension movement, then the spring rates rapidly increase and leave the shocks inadequate. Or the rates are just too high for the shocks. Or the shocks are already blown. Or a million other possibilities.
It's really impossible for us to diagnose a suspension issue over the internet, more so with modified suspensions (how much shock travel is left at static ride height before bumpstops are hit, how much total shock travel is available, and many other questions that need to be answered), and especially the way people typically fail to adequately describe what the car is actually doing.
Stop looking for a single part solution. Start looking at the suspension system as a whole, to find an actual solution.
Ricky07
Suspension & Brakes
35
Feb 20, 2013 10:46 AM
B18C_DD
Suspension & Brakes
Aug 11, 2006 07:01 AM
integraboy22
Suspension & Brakes
Jan 24, 2006 05:31 AM
natasD5nt
Sep 1, 2003 09:12 AM
integ_newbie
Aug 10, 2001 09:01 PM
