Alternator or Battery?
Ok so my car sat for two days while i had to replace a caliper. When i got in it to leave i went to start it and everything inside came on(radio, Dash Lights, LEDs) But it was bogging down as if the battery was dead. In the last three days it has done this twice. Any advice would be greatly appreciated.
With multi meter check battery with car off it should be 12.4 iirc volts if not its battery (if it is proceed to nxt step)
While running it should be 14 if not its alt
turn the car on and while running disconnect the positive terminal and if the car shuts off your alternator isnt charging enough if it stays on then go to autozone and get your battery checked
Not the wisest thing I have done, but oh well.
The alternator does have potential to do a momentary spike and blow out electronics.
You CAN still fry an ECU or the car stereo. It's completely possible,
You can even fry the diodes in the alternator itself.
The theory is that if you disconnect the battery with the engine running, then the alternator will take over to keep the engine running.
If the engine dies, then the alternator is supposedly bad.
The downside is that if the engine stops running, then the alternator might be perfectly fine and you just blew out the ECU.
Compare voltage across the two battery posts under these three conditions:
1) Engine off -- should be ~12.5V to 13V
2) Warm engine idling with all electrical accessories off (no electrical load) -- should be ~14.2V to 14.4V
3) Warm engine idling with high beams on, A/C on, and cabin fan on high (high electrical load) -- should be ~13.9V to 14.2V
fw190bvi
Jul 27, 2007 09:52 PM
'90crxSI
10
Sep 28, 2006 05:23 PM
