Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tranny problem(release bearing fork)
Old Sep 15, 2012 | 06:59 AM
Boo$ted's Avatar
Default Tranny problem(release bearing fork)
Hey guys how's it going so first off I'll start off by telling you that my car is a 95 civic si b18b forced induction. Over the winter I did some major work to the car and while my motor was out decided I'd pull my tranny off and inspect my clutch. Now I'm in the reassembly stage and I go to put my slave cylinder back on and fully compressed the bolts barely and I mean barely match up with the bell housing. It's seems my release baring fork is not moving to the passenger side far enough? Any ideas what's up? Also any question that could help you solve my problem please ask!! Thanks eh!
Old Sep 15, 2012 | 09:26 AM
David @ Synchrotech's Avatar
Default Re: Tranny problem(release bearing fork)
Check the fork to be sure it is securly on the pivot ball and correctly attached to the throw out bearing.
Old Sep 15, 2012 | 11:05 AM
Boo$ted's Avatar
Ok I'll try that this weekend. Also is it at all possible I could have accidentally put the clutch plate on backwards? So it causing it not to be able to move far enough over?
Old Sep 15, 2012 | 01:59 PM
It is probably just the fork not being under the tabs on the TO bearing. Let us know what you find...
Old Sep 15, 2012 | 06:37 PM
Boo$ted's Avatar
I will forsure hopefully get around to it Sunday have family coming in from out of town but should be as to squeeze it in lol
r.f.b
13
Nov 2, 2017 06:45 AM
PphamEK
Feb 3, 2009 06:40 AM
dcdcdc
Mar 20, 2008 11:35 PM
Wheelman-CZ
10
May 27, 2006 11:50 AM
DJ_SaNdOz
May 6, 2003 03:06 PM
