y7 head on a6 block?
Old Sep 14, 2012 | 06:55 PM
socialistic's Avatar
Default y7 head on a6 block?
I'm running pretty much Si-everything on my '90 DX hatch and after replacing the valve stem seals, valve cover gasket, spark plug tube gaskets, and rocker assembly o-rings I'm still losing a lot of oil. I blow clouds of smoke after letting the engine brake and getting back on the throttle. Compression was above recommended across all four cylinders last I checked and the smoke doesn't seem to be constant. Everything seems to point at the valve guides.
I don't really want to invest any more money in this car as I'm trying to get a past integra project back so going VTEC isn't really an option. Earlier tonight my buddy hooked me up with a complete and clean y7 head and said I should be able to use that.
Can I use a y7 head on my a6 block? It's a complete head with no distributor or intake manifold. I can rob any parts from my a6 top-end that I need but I want to be sure it'll bolt on to that new head and that new head will bolt on to my block. What head studs and head gasket can I use?
ETA: Found this...
http://www.d-series.org/forums/136690-post5.html
...but it was posted 8 years ago and the thread didn't carry on any further.
Old Sep 22, 2012 | 01:58 PM
Default Re: y7 head on a6 block?
TTT
Old Sep 22, 2012 | 02:02 PM
ef yu's Avatar
if the setup worked 8 years ago, what makes you think it wont now?
Old Sep 22, 2012 | 02:04 PM
"Yes it will work" isn't a very good explanation, hence this thread. Generally one would want to know the specifics of such a swap before actually performing the swap.
Old Sep 25, 2012 | 08:43 PM
TTT.
There's gotta be at least one person around here that's done a y7 head on an a6 block.
Old Sep 25, 2012 | 09:29 PM
661rex89si's Avatar
same as swapping a z6 head. just use one y8 head stud the rest z6/a6
Nick Azzarto
Jul 20, 2014 05:28 PM
boostedhks
Aug 27, 2008 07:29 PM
hb_guy
Jan 16, 2006 07:31 AM
killer6993
Feb 18, 2005 12:11 PM
C4wrx
Aug 4, 2002 06:23 PM
