Vibrant Flat Black 3" Oval Muffler, 850cc Injectors, 4bar plug & play map sensor NEW
BRAND NEW
Vibrant Performance Flat Black 3" Oval "Sleeper" Mufflers
Part Number # 1147
Inlet Diameter: 3"
Tip Style: 3" Round Tip, Angle Cut (Single Wall)
$125
Osidetiger 850cc (high impedance) No Resistor Box Required - $240
I paid 256 for these and they are still new.
Have all the paper work, new, flow tested.
92-95 civic/del sol/ integra plug and play, no resistor box needed.
96-00 civic/integra need jumper harness.
Still under 1 year warranty that expires 04/11/13 All paper work will be included.
http://www.osidetiger.com/SiteImages/11mmfit.jpg
Speedfactory plug and play 4bar map sensor - $80
-new
-fit civic/delsol/integra
Speedfactory 4 Bar MAP sensors use state of the art bipolar op amp circuitry with thin film resistor networks built into each micro chip. Pressure changes are calculated on a true linear 0-5 volt scale via a specially designed silicon pressure sensor that also compensates for temperature changes. The unique ability to compensate for temperature changes allows our MAP sensor to remain a minimum of 99% accurate from 32 degrees F to 180 degrees F through out its range of scale. With the true linear pressure vs. voltage scale there is never a need to re-tune at different altitudes as with other sensors. Speedfactory 4 bar MAP sensors can precisely calculate boost pressure from 1-43+ psi while still allowing smooth stock OEM drivability at any boost level. Conveniently packaged in an OEM dimensional housing for easy install and an OEM look.
Part Number # 1147
Inlet Diameter: 3"
$125
-new
VegasInvasion
Engine Management and Tuning
Feb 23, 2015 10:30 PM
zerovandez
Sep 14, 2007 04:56 PM
95c1v1cs1
May 8, 2003 11:25 PM
