Alex_S - Honda Civic ED7 88' Build
Old Sep 14, 2012 | 02:47 AM
Alex_S's Avatar
Default Alex_S - Honda Civic ED7 88' Build
Hey! im now back with another Honda. I managed to get this 88' ED7 real cheap!
D16A6 engine, discs at rear. It also had the rear fenders and both thresholds changed at a bodywork shop, not too long ago.
It's pretty much rustfree.
When i bought it, the engine wasn't in it cause the previous owner had plans to but a b16 engine in there but he never got around to it.
__________________________
Plans:
repaint - Either Barrakeshbrown or championship white
Amber positionlights
paint the plastic in the headlights black.
Coilovers
strutbars front and rear
headers + custom made 2" exhaust
CAI
pretty empty!
Starting to put the engine back in!
_
Driveshafts are on !
Engine is in all mounts except the gearbox one.
Engine is in!
On it's own feet!
Bonus pic!
Old Sep 14, 2012 | 02:55 PM
Alex_S's Avatar
Default Re: Alex_S - Honda Civic ED7 88' Build
Got some more done tonight! Still waiting for a new engine harness so the startup bit will have to wait some.
Started the modification of the valve cover, the Honda badge and text is removed
Also changed the fender as the old one was rusty, so i took the time to put some paint under it.
Old Sep 14, 2012 | 04:19 PM
JDpower's Avatar
Very nice I like it, nice find on the Si.
Old Sep 15, 2012 | 02:15 AM
Alex_S's Avatar
Thanks!
Old Sep 15, 2012 | 02:02 PM
Alex_S's Avatar
Hasn't happened so much today.. Made some more progress on the valve cover, still not done by far!
Old Sep 19, 2012 | 11:14 AM
Alex_S's Avatar
Got my new harness ! theres just some plugs i need to know where they go
The contact
to/from injectors? where are they supposed to be connected?
I could also use some pictures of where all the ground points are in the engine bay!
Old Sep 19, 2012 | 11:33 AM
4drEF's Avatar
Keyboard Humorist
1st pic is the fan switch. Located on the back of the motor near the oil filter.
It's the one with the two prongs in this picture.
http://img338.imageshack.us/img338/5435/pict0909.jpg
Second one looks like the MAP sensor connector and some cut wires for what used to the the purge cut solenoid.
These are found on the firewall as show in this pic.
http://crxcommunity.com/viewtopic.ph...59912&start=50
Green plug in your last pic is definitely the injector resistor box.
Old Sep 19, 2012 | 11:58 AM
Alex_S's Avatar
Thanks man!
Heres a pic of my resistorbox, this is the only connection to it? should the green one go in to that one then?
Old Sep 19, 2012 | 12:07 PM
4drEF's Avatar
Keyboard Humorist
Green one goes in there
http://i.ebayimg.com/00/s/NzY4WDEwMj...id=8800005007;
The heavier yellow/black stripe in that connector goes to your main relay for +12 volts.
The reds go to each injector to give them +12 power.
The other connector goes to a firewall connection for this plug.
Your connector is rectangular which is only found on the 88. 89~91 is round.
https://honda-tech.com/forums/showpo...07&postcount=2
Pic in that link doesn't show the chassis harness/firewall connection.
Old Sep 19, 2012 | 12:18 PM
Alex_S's Avatar
Okay thanks! will look closer at the firewall for the connector tomorrow!
Old Sep 19, 2012 | 06:37 PM
M-benz's Avatar
These go to the thermo switch sensor behind the block near the oil filter .
Old Sep 19, 2012 | 07:38 PM
habanerored06si's Avatar
Grats on build.
Subscribed
Old Sep 19, 2012 | 08:57 PM
Alex_S's Avatar
Originally Posted by habanerored06si
Grats on build.
Subscribed
Thanks!
Old Sep 20, 2012 | 11:48 AM
Alex_S's Avatar
Just got back from the garage!
The cables for the injector resistor are now in place!
Where should this be connected? it seems to be too small for anything in its reach.
And where is this one supposed to be connected?
Now down on my new garage spot! will be accompanied by my mates S13 soon
Old Sep 20, 2012 | 12:52 PM
Alex_S's Avatar
nevermind about the earth's, they went to the fusebox (duuh) :D
Old Sep 20, 2012 | 03:51 PM
xxOldschoolxx's Avatar
Second goes to the starter.
Old Sep 20, 2012 | 04:17 PM
4drEF's Avatar
Keyboard Humorist
Third pic -
One cable on that battery terminal runs to the starter and the other to the fuse box.
In your pic, I can see the part of the fuse box where the wire is supposed to enter.
Where does the other cable run that is hooked to the battery terminal?
You are also missing the heavy gauge cable that runs into the fuse box from the alternator.
In this pic (not mine), somebody replaced the stock battery cable with a red one.
The black one right next to it runs to the alternator.
The lug you show in your second pic MIGHT be that alternator wire.
Old Sep 21, 2012 | 01:59 PM
Alex_S's Avatar
The car is started! i just need to get a little gasket for the fpr, as its leaking some fuel at the moment.
Then i have to connect the last of the remaining vacuum lines and some small things like that.
Then i can start to bleed the brakesystem and coolant :D
Old Sep 21, 2012 | 07:04 PM
Whens the turbo coming?
Or even AWD conversion? Gotta be a Civic Wagon somewhere in Sweden
Old Sep 22, 2012 | 02:58 PM
Alex_S's Avatar
Been thinking about doing a awd conversion, i just gotta find a wagon. There are some in sweden, but they're still really rare.
Old Oct 1, 2012 | 10:56 AM
Alex_S's Avatar
Got a little done today.
rebuilt the exhaust somewhat, fartcan atm but will have to do until i rebuild the entire system
Started making a template for my Chargespeed look-a-like wing :D
Starting to take shape, a-la pizza style
Old Oct 2, 2012 | 06:32 AM
ap2ef8eg6's Avatar
nice keep it up!!!
Old Oct 5, 2012 | 05:07 PM
Alex_S's Avatar
Was at the garage a bit tonight, was more talking than working though haha
Started to fix some rust on the passenger door
The engine is also starting to fall in place, the shine is real bad atm. After inspection i will do some wire tuck, move the battery to trunk and some more stuff
Old Oct 8, 2012 | 01:30 PM
Alex_S's Avatar
removed the interior and started some dieting
Not alot left now
Also one of the more fun plans for the coming summer
TD04 or Garret T25
3" DP - - 3" exhaust, no cat
Homemade header
Malpassi FPR
S13 370cc injectors ( for a start )
colder spark plugs
recirculating dump valve
stiffer clutch
saab 9000 intercooler
will be run on an unopened d16a6 engine and running 98 octane ( will run E85 if i find bigger injectors )
target 150 - 200hk ~
Old Oct 10, 2012 | 01:40 PM
Alex_S's Avatar
Alright! trashing the turbo plans.
new plan!
go through the engine
Porting the head
P29 / pm7 pistons
D16z6 headgasket
this will get me to ( according to calculator ) 11.10 in compression ratio
will combine this with a 4-2-1 header and 2" exhaust without cat.
What you think of this setup? got any better ideas?
