FUEL / COOLANT GAUGE NOT LIGHTING UP
Old Sep 13, 2012 | 10:34 AM
LatnKng's Avatar
Icon2 FUEL / COOLANT GAUGE NOT LIGHTING UP
Question..my coolant and gas meter gauges on my dashboard not lighting up..so i cant really tell if my car is overheating or how much fuel i have. Whats the easiest way to fix these two issues besides replacing the bulbs or the dash??
Old Sep 16, 2012 | 12:53 PM
razorlude's Avatar
Default Re: FUEL / COOLANT GAUGE NOT LIGHTING UP
1.buy after market meter and wired it up.
2.replace the fuel/temp cluster.
Old Sep 27, 2012 | 02:24 PM
LatnKng's Avatar
I just got back from the junkyard..no luck finding one intact. Don't want to spend too much online.
Old Sep 28, 2012 | 06:43 AM
snobordboy's Avatar
Moderator
Did they just stop working out of the blue? I would wonder if the plug vibrated loose, or a wire has been compromised in the harness, so a new gauge may not fix the problem.
Old Sep 28, 2012 | 10:53 AM
afrotec's Avatar
Yeah, check your wiring. you could even use a multimeter while the car is running to be more precise about it. then replace the cluster, theres a member on PreludePower selling several clusters for a nice price.
Old Sep 28, 2012 | 04:28 PM
TheJGB3's Avatar
When you say not lighting up - do you mean the cluster lights that light up the fuel & temp gauges aren't working, or the gauges themselves aren't working?
Old Oct 19, 2012 | 07:56 AM
LatnKng's Avatar
Hey guys..sry I'm jus replying...and yes the fuel and temp gauge not working..It started flickering and then just went out..I've checked and double-checked. Didn't do multimeter check though..replaced it twice with other ones and same issue.
Two2ManyHondas
Nov 1, 2013 09:29 PM
raverx3m
Oct 19, 2013 11:08 AM
Mr. 1582
Jan 4, 2004 02:03 PM
Mr. 1582
Jan 4, 2004 01:48 PM
