''Best design'' for a manifold.
Because exhaust pressure will be through the roof.
Backed up pressure in an intake manifold is "boost," backed up pressure in an exhaust manifold is heat stuck on the exhaust side of a cylinder head. It also leads to concerns about evacuation of exhaust gas from the chamber.
You could easily build block hugger headers that would fit in an equality tight clearance if you're a skilled enough fabricator.
Agree on troll post.
Whoever built that clearly does not understand physics or the combustion cycle.
Who is Mr Robot?
you should see the **** those idiots on v8nissans post about manifolds, anything technical about motors, catch cans, etc, and this particular setup.... when i try to tell someone how to do things properly they just bitch and moan at me and say but it works
smh
smh
sounds like s2ki.com....
RDX2010
Oct 6, 2017 05:59 PM
