my DIY tie bar and trunk bar
its made from some aircraft quality aluminum rated at 47si.
here's a sample of the aluminum bar
my trunk bar using the rest of the aluminnum
i used a dremel and a drill to make the notches. i noticed a difference but it wasn't as drastic as the type-r sway bar, plus they look nice haha
woah, impressive. how much prior experience did u have before doin that?
put me down for 1
put me down for 1
they hold the bumper to the car.
Alloy 2024 Aluminum Rectangular Bar 1/2" Thick, 1" Wide, 6' Long
$ 38.83 Each
Hmmm
Check out: http://www.mcmaster.com
Look under the "metals" subsection
Good luck
89215K41
$ 38.83 Each
Hmmm
Good luck
89215K41
$ 38.83 Each
Hmmm
the place where you put the trunk bar is not where you would put the benen strong bar(just in case- this bar is the bar that allows you remove your rear bumper support) is it?
