what paint to use when painting turbo???
Old Oct 16, 2002 | 06:59 PM
its WANG yoO's Avatar
Default what paint to use when painting turbo???
ok i want to paint my turbo...the compressor side is polished so what do i paint the other half with? is there a paint that won't flake off at high heat???
thanks alot!!!
Old Oct 16, 2002 | 07:14 PM
sutrusu's Avatar
Default Re: what paint to use when painting turbo??? (hybridRhatch)
your turbo gets really hot... unless you get it jethot coated (orsomething like that) it's going to burn off.
Old Oct 16, 2002 | 08:42 PM
mos's Avatar
mos
Default Re: what paint to use when painting turbo??? (sutrusu)
Brake caliper paint? BBQ paint? Engine block paint? no? ?
Old Oct 16, 2002 | 09:43 PM
FredoSP's Avatar
get some temp that can with stand some high temps, but why would you do this if its going to be tucked away under the car?
Old Oct 17, 2002 | 09:49 AM
turbosol's Avatar
Default Re: what paint to use when painting turbo??? (FredoSP)
VHT Flameproof paint found at NAPA. I did my manifold an down pipe and it's holding up great. I got the silver kinda looks like a ceramic coating. I would have done the turbine housing but I was too impatient. I didn't have the turbo for 2 month and when it came in I wasn't going to wait to paint it. Anyway, good paint!
Old Oct 17, 2002 | 08:41 PM
zexdrex's Avatar
Default Re: what paint to use when painting turbo??? (turbosol)
i used aircraft flame retardant paint good for about 2300 degrees!!!!
Old Oct 17, 2002 | 09:44 PM
ninesecrx's Avatar
Default Re: what paint to use when painting turbo??? (zexdrex)
Pretty much most of the over the counter paint will flake off with that kind of heat. Even having it jethot coated wears away on the turbo after time.
Old Nov 20, 2002 | 05:22 AM
TurboCRVTEC's Avatar
thanks alot!!!
http://www.por15.com
Old Nov 20, 2002 | 05:48 AM
Willard's Avatar
Default Re: what paint to use when painting turbo??? (ninesecrx)
there are few coatings that will last at 1500f-1800F for extended lengths of time.
Old Nov 20, 2002 | 03:25 PM
mos's Avatar
mos
Is there such a thing as 2300 degree paint? Where do i sign up?
i used aircraft flame retardant paint good for about 2300 degrees!!!! <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emwink.gif" BORDER="0">
Old Nov 20, 2002 | 03:28 PM
E-Rok's Avatar
EPIC TUNING
Default Re: what paint to use when painting turbo??? (mos)
i used some engine paint thats good for 1200 degrees, we will see how long it lasts.
Old Nov 20, 2002 | 03:40 PM
JV's Avatar
JV
Who?
I use this stuff on everything. It hasn't flaked, faded, or peeled yet...
Stovebright
tweensquirt
Acura TSX
Mar 12, 2012 05:58 AM
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
peiku
Jul 25, 2005 10:49 PM
vdub08
Nov 4, 2004 04:38 PM
