broken bottom strut bolt
Old Sep 11, 2012 | 07:20 PM
Thomas Williams's Avatar
Default broken bottom strut bolt
I was replacing the springs,on my car and came across the bottom bolt in the rear that holds the strut in place was seized and I broke to head off of it....is it possible to get it drilled out?
Old Sep 11, 2012 | 09:57 PM
6_Speed's Avatar
Default Re: broken bottom strut bolt
If the bolt is threaded through a nut on the opposite end, can you tap the end of the stud where the head broke off through the knuckle with a punch?
Old Sep 12, 2012 | 05:10 AM
Imma have to try that when I get home today
Old Sep 12, 2012 | 05:13 AM
badcb7's Avatar
the nut on the opposite end is part of the strut i believe. im not sure what you can do to get the broken bolt out but you might have to get a die grinder and cut the strut to remove it and buy a new strut. its not a bad idea if your lowering your car.
Old Sep 12, 2012 | 12:20 PM
The struts that I have seen for my car that nut is not attached to to it
Old Sep 12, 2012 | 08:01 PM
FRANKENSTIEN813's Avatar
Get a Punch and a L-Hand Drill bit PB Catalyst the hell out of it
and drill away.. Harbor freight sells the bits cheap you'll use a few
Old Sep 12, 2012 | 09:26 PM
10psiLsEf2's Avatar
it should be part of the strut.
happened to me many of times.
i just used a angle grinder and ground off the nut. and then hit it out with a punch
solfire
Dec 3, 2010 12:51 PM
spens 91 Ef
Oct 8, 2008 05:44 AM
GSR_hatch936
Nov 13, 2007 02:58 PM
komat
20
Dec 26, 2004 10:04 PM
