Need Help Removing Rear Shocks!!
Old Oct 16, 2002 | 06:40 PM
Flux's Avatar
Default Need Help Removing Rear Shocks!!
I'm installing a new set of coilovers and I cannot get the rear shock out of the car. I have removed the bolt at the bottom of the shock, the bolt on the locating arm, and the bolts on top of the shock inside the hatch.
I am pushing down on the rotor to so I can pull the shock forward and out, but I can't get enough clearance to yank that sucker out. I have GAB shocks, so the adjuster on top of the shock may be a bit taller than the stock shocks. I have pushed down on that rotor as hard as possible (full weight) and it still will not clear.
Any advice?
[Modified by Flux, 9:41 PM 10/16/2002]
Old Oct 16, 2002 | 06:41 PM
Reid's Avatar
Global Moderator
Default Re: Need Help Removing Rear Shocks!! (Flux)
If you're having a hard time, try disconnecting the rear swaybar.
Old Oct 16, 2002 | 06:42 PM
sackdz's Avatar
Default Re: Need Help Removing Rear Shocks!! (Reid)
Yep that's what I did, worked for me.
Old Oct 16, 2002 | 06:43 PM
Haunt's Avatar
Edit: Maybe thats the rear sway bar...
Anyway...follow the arm back and take the one bolt off...lower the rotor and you should barely be able to pull the shock out...
Hope that helps...sorry about my lack of knowledge of car part names...
Any advice?
[Modified by Haunt, 10:44 PM 10/16/2002]
[Modified by Haunt, 10:46 PM 10/16/2002]
Old Oct 16, 2002 | 06:44 PM
D's Avatar
D
you don't have to remove the rear swaybar... just have to have some skills.
D
Old Oct 16, 2002 | 06:47 PM
Flux's Avatar
That worked perfectly.. I should have thought of that...
Thanks!
Old Oct 16, 2002 | 06:55 PM
tonyxcom's Avatar
Also, you can make sure you have the whole rear end jacked up, then press on both rotors at the same time with both shocks disconnected.
Old Oct 19, 2002 | 08:02 PM
Cosworth's Avatar
Fawk, I think one of my swaybar bolt is semi-stripped. Is there any "glue" to seat the thread? I can't get the required torque spec on the top D-bracket sway bolt (bottom one is on tight)... **** rotates forever.
Old Oct 19, 2002 | 08:20 PM
tonyxcom's Avatar
Default Re: Need Help Removing Rear Shocks!! (Cosworth)
On the SI endlinks, there is a allen head in the endlinks so that you can hold them while you tighten it. I would guess the ITRs have it the same?
Old Oct 19, 2002 | 08:23 PM
Cosworth's Avatar
Default Re: Need Help Removing Rear Shocks!! (tonyxcom)
No, the bolt goes into the subframe with pre-fabricarted threaded slot. That's what pisses me off, don't think I can re-thread the damn subframe. I am going to order a new bolt and see if that fixes it...
Old Oct 19, 2002 | 11:29 PM
tonyxcom's Avatar
doh, I missed the part about it being the d-bracket bolt.
I would drill the threads out, get a longer bolt, and put a nut on the end.
metroya_performance
Aug 15, 2007 12:11 PM
sik94hatch
Apr 11, 2006 05:06 PM
Nerv2g
30
Oct 24, 2003 01:09 PM
EL-Driver
Apr 6, 2002 06:34 PM
