blue top vs non blue top
can any one help me out with what the diffrence is between a blue top h22 vtec head and the non blue top, in hp gains and over all performance ? also diffrence in pricing thanks in advance
Check forum FS threads, there's usually someone parting out a setup and you can usually pick up something cheaper than through hmo.
If you're not comfortable with that, then go with a JDM H22A from hmo.
One way or the other, just make sure you get the JDM ECU if you aren't planning on tuning. I believe the JDM ECU is tuned a bit better from the factory.
