team1320_k26eg Part Out: ATI Damper/Injectors/DogBox/Hood Exit Header/Rywire/Etc.
Here are some of the parts i have left from my apart out. i haven't had time to price everything out but i will as soon as i get a chance. i have listed some of the parts on eBay but i will end the auction early if i have potential buyers on here. I'm gonna list what i have and price as many things as i can right now. shipping is at buyers expense unless specified. i will add pictures of all items very soon. If you are local I will entertain trades for the trans. I am in the market for a DD. car, small truck or suv, maybe even a street bike.
1.) K-series Stepped All Motor Hood Exit Header by GO-Power Motorsports. Must have tucked brake lines and relocated battery to run this. The header retails $1600 new with a 8 week turn around time so save money and get it a lot faster. The header is made of stainless steel and has a reverse megaphone. -$1200 shipped
2.) ATI Super Damper Crank Pulley. -$325
3.) Fly Wheel Trans Scatter Shield Powder Coated Gloss Black -$100
4.) 2 Sets of GO-Power Motorsports GP-750cc/1000cc Bosch injectors. These are 750cc but can Also Work as 1000cc Fuel Injectors with the Fuel Pressure set @ 80 psi. -$300 shipped for each set.
5.) Shifter Box, Shifter Cables and Karcepts Relocating Shifter Plate. -$250 shipped
6.) K-Swap Axles -$
7.) PAR Dog Box Trans with a 4.7 FD and Quaife LSD -$ (might be pending locally)
8.) Rywire Milspec Wire Harness Wired for AEM Pencil Coils, Also Wired for Optional 8 Injector Set Up. -$1000
9.) Aem Pencil Coils. -$
10.) OEM Coils. -$80
11.) Skunk2 Intake and Exhaust Adjustable Cam Gears. -$
12.) Clutch Masters FX700 Twin Disc Clutch and Flywheel Set Up. -$900
13.) Passenger Side Motor Mount Bracket for K24. -$40
14.) Timing Chain, Timing Chain Cover, Tensioner, Head Studs. -$
15.) Misc sensors. -$
16.) Water Neck with welded -AN fitting Powder Coated Gloss Black. -$
17.) Midshaft -$
header on the car idling. i know, i should have popped the hood.
6.) K-Swap Axles -$
17.) Midshaft -$
wasanissanFL
Jan 8, 2016 11:49 PM
team1320_k26eg
Dec 29, 2013 01:47 PM
team1320_k26eg
Sep 8, 2012 04:14 PM
