Suspension & Brakes Theory, alignment, spring rates....
DA front brakes on a EG
Old Sep 10, 2012 | 04:54 PM
Tkrizz's Avatar
Default DA front brakes on a EG
So i've been doing a lot of research and im finding a ton of people saying you cannot use 90-93 integra front brakes on a 92-95 civic because it screws up the camber. I'm also finding a couple posts saying you can but keep the civic UCA as that's what affects the camber.
What i'm wondering is if anyone can clarify this information? Maybe someone who has done it or had a buddy that did it or tried it? Parts are hard to find around here and I have access to a 90 integra ls so i just need to know if this works for sure so i can go ahead and get them. Thanks
Old Sep 11, 2012 | 07:03 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: DA front brakes on a EG
The knuckle is the only thing that would mess up the camber if that was even true but it is not!!! I believe the only difference between 90-93 DA and 94-01 DC is the caliper mounting bracket is different. The 90-93 bracket uses a smaller brake pad but they use the same brake caliper as 94-01
Old Sep 11, 2012 | 07:39 PM
Tkrizz's Avatar
Awesome good to know! I'll pick them up then and hopefully they work.
Old Sep 17, 2012 | 06:53 AM
Fester LOD's Avatar
you will have about 7 degrees of camber you need to yous dc spindles for it to wrack i tried this on my eg and i went thru a per of tiers every month.
Old Sep 20, 2012 | 08:00 PM
Do you speak english??? 7 degrees huh??? I call BS all day long!!!! It has been done time and time before with no problems. If you had -7 degrees of camber you had some serious chassis issues and those knuckles were not your problem.
Old Sep 22, 2012 | 07:42 PM
98civdx's Avatar
Master Detailer
-7* and the wheels will be damn near ******* sideways.
nihad
Jul 16, 2009 01:48 PM
95blackEG
Nov 23, 2008 10:06 PM
UrbanEh
Feb 1, 2007 03:35 AM
g-ride-si
Sep 23, 2005 12:29 PM
RTW DC2R
Aug 9, 2003 01:50 PM
