Suspension & Brakes Theory, alignment, spring rates....
Wheel set back after collision
Old Sep 10, 2012 | 11:50 AM
FearSC549's Avatar
Default Wheel set back after collision
I got into an accident and the damage was around the driver side front fender. The front part of the fender is crushed and a little part of the hood is damaged. My tire was also slashed by some metal part and now I noticed the wheel sit a little behind the passenger side wheel. I looked it up online and found out that's called a set back.
Does anyone know which part most likely is bent? I can see that the front sway bar on the passenger side endlink is vertical, but the driver side is slanted. I know something is bent but I can't tell right now because I still have to wait for the insurance company to inspect the damage.
Old Sep 10, 2012 | 04:05 PM
TPB's Avatar
TPB
Default Re: Wheel set back after collision
Could be lower control arm and/or lower sub frame
Old Sep 10, 2012 | 04:31 PM
1998GsRIntegra's Avatar
Sounds like lower subframe. Had the same thing happen to a crx that was turned down on entering a corner because the other driver wasn't checking mirrors. Basically replace parts until it straightens out. That's what they do at dealerships.
Old Sep 10, 2012 | 04:37 PM
FearSC549's Avatar
How do I tell if it's the lower subframe? I did a visual inspection and it seems straight and even like the passenger side. I know visual inspection doesn't mean ****, but the only way to find out is to swap parts until it's straight right?
Old Sep 10, 2012 | 04:38 PM
MonkeyMagic's Avatar
"Does anyone know, from the pictures and measurements I didn't include, which part is bent?"
Are you really, truly serious?
Old Sep 10, 2012 | 04:48 PM
Lol, don't ya know we're all a bunch of ******* miracle workers that can just guess and be right. Pictures would really help.
Old Sep 11, 2012 | 12:04 AM
FearSC549's Avatar
I didn't ask which part is bent, but I was asking which part might be bent/damaged.
I'll take pictures in the morning
Old Sep 11, 2012 | 02:27 AM
grumblemarc's Avatar
The Grumpiest
THAT'S THE SAME BLOODY THING!!! You're just mincing words. How about get under your car and actually look for the damage!
Old Sep 11, 2012 | 06:01 AM
ok, well the correct answer is: any of them.
this
Old Sep 19, 2012 | 12:45 AM
FearSC549's Avatar
I'm going to take the lower control arm out tomorrow after soaking the joints and bolts with PB blaster.
I can't tell if anything is bent since most of the suspension parts are forged metal. If it was like a sheet metal, like the upper control arm, it would've been easier.
mimog3
17
Aug 12, 2024 05:29 AM
Kanga
Mar 7, 2016 07:27 AM
KiNGDEE206
Dec 19, 2014 04:15 AM
B20HmongHatch
Suspension & Brakes
15
Dec 10, 2012 09:30 AM
vteck1ck
17
Apr 4, 2010 03:20 PM
