d16y7 to d15b swap need help
ok i have a 97 ex ek that i recently took the d16y7 out of it and bought a d15b head and block out of a auto 95 coupe. ok this was my first swap doing by myself. i took the dizzy,altnator,intake off the y7 and put it on the d15b now everything mounts up but the dizzy can only mount using 1 bolt frm the way it came off the y7. i broke the plug rit by the oil filter (i think is the oil pressure sensor) but i was told that didnt matter. now i no the d16y7 is odb2 and the d15b is obd1 but im using my stock y7 harness because im not trying to wire vtec up rit now i just want it to start. now its getting spark fuel pump turns on but when i try to start it it sounds like it wants to turn over but dosent like its not gettin enough fuel or i dont know if the firing order is suppose to be for the d16y7 or d15b i just need to no if any1 has done what im doin and if it workd. ive bin doin this swap for a week now and was suppose to have this done in 2days. i have no idea on what is wrong with it and why its not starting all my grounds are hookd up all my connections are connected but i just dont no if i have to use the d15b dizzy or intake or im good. any advice would help cuz rit now im stuck.
for people whos lost on what im doing...
d16y7- tranny,altnator,dizzy,intake,injectors
on a d15b head and block
1.car isnt starting, almost turns over.
2. fuel pumps turns on
3.getting spark
4.need help pm if you think u can help or jus dnt get what im tryna say
3.getting spark
i dont no which cam gear is used what is that? and i put the dizzy on just like it was on the old motor so timing should be right. i dont no how to check the timing and what map and tps sensor are you talking about. when i plugged everything back in it basically was easy bcuz everything went where it was suppose to go like i said its my first swap im doing by myself. and thank yall for tryna help. i dont no if its the ecu which is a p08 i think whatever comes with the stock d16y7 or i need the d15b dizzy i dont no.
crxfornow
Mar 19, 2020 10:27 AM
