d16y7 Turbo Build begins!!
Old Sep 9, 2012 | 07:03 PM
JFields95's Avatar
Icon3 d16y7 Turbo Build begins!!
I have a 1989 Honda civic dx hatch with the stock d15b2 in it that is in need of replacement.
I have several things I want to do with this car. My overall goal is 200hp, nothing crazy as this will be my DD but I want the power to be there when I need it.
I definitely want to turbo whichever engine I put in there (explained more down below)
Basically what I need from you guys is your opinions on what I should do. Either a d15b with the 3 stage VTEC, or D16y7. If i went the Y7 route would it be better to do the mini me swap on it and then turbo it? And where would I get all the necessary parts for the swap?
What should I replace on the internals?
Which brands would you recommend and from where I can get it from?
I also wanna know what you guys would recommend as far as turbos and from where to get one.
This is very much a budget build, so bare that in mind.
Thanks very much for your time! Any help is appreciated.
Old Sep 9, 2012 | 07:38 PM
norcal69's Avatar
Default Re: d16y7 Turbo Build begins!!
I'm thinking of building a d15b7 on boost myself. If your going to swap your motor anyway why not just do a DOHC swap you could always boost that later and produce way more power.
Old Sep 9, 2012 | 07:43 PM
JFields95's Avatar
I want it to be a SOHC, I'm just particular like that. Which do you think will be better for 200hp?
Old Sep 9, 2012 | 07:53 PM
v8killaz's Avatar
if you want a sohc id go more displacement with the 1.6.
Old Sep 9, 2012 | 08:00 PM
JFields95's Avatar
Thanks for your input, can you answer anymore of the questions in the OP?
Old Sep 9, 2012 | 08:12 PM
v8killaz's Avatar
do a vitara build and you should handle 300whp easily reliably. get it tuned.
http://go-autoworks.com/ for parts
Old Sep 10, 2012 | 04:30 AM
JFields95's Avatar
Thanks, I've also heard people talking about Eagle rods, would that be a wise decision to do? They're expensive as hell or I would definitely do it, maybe what would be the rods you would recommend? Also what else should I get? New springs or ARP headstuds? I mean is it necessary?
And I've also heard that the Vitara positions are .060 longer so the rods need to be shorter then stock rods, where might I find those?
I know, a lot of questions, just trying to get as much info as possible.
Old Sep 10, 2012 | 10:07 AM
v8killaz's Avatar
all that has been covered in the forum. i have those answers but you have to do some research
might want to check out other forums as well like d-series.org
Old Sep 10, 2012 | 10:49 AM
grumblemarc's Avatar
The Grumpiest
Or www.spoonfedturbos.com.
FAQs. Read them. Build threads. Review them.
Old Sep 13, 2012 | 04:57 PM
norcal69's Avatar
If your going for 200 hp then your 1.5 is going to be ok. I have been reading into this a whole lot and it looks like I'm going to start with a greddy kit on my d15b7. While I'm driving that around I will be buildint a fully built d16z or y motor. I wanted 200-220 hp but after reading and hearing this guys pushing over 400hp (on a fully built) SOHC motors I want to see just what I can do. Here is another thing what are you setting your car up for? I live in california so it is going to be hard to get a fully built motor with a turbo to pass the state ref and get a BAR sticker but where there is a will theres a way and I will keep a thread updated when this all starts.( I hope)
Tagman87
18
Jun 12, 2012 07:44 AM
toshko321
Aug 27, 2009 11:06 PM
swiss217
16
Jun 28, 2007 03:46 PM
civichb13
12
Nov 5, 2005 03:16 PM
wrXtian
10
Sep 17, 2002 08:09 PM
