FL For Sale - 1995 Del Sol Si LS/Vtec Turbo
Old Sep 9, 2012 | 11:22 AM
lzylst's Avatar
Default For Sale - 1995 Del Sol Si LS/Vtec Turbo
1995 Honda Del Sol Si - $8,000 obo
Vance @ 863-604-2139
This car was about a 12month project worked on by me in the garage in the evening and on weekends as time and money permitted, most items were purchased new by me with receipts for proof. At this time there are 100k original miles on the chasis and under 10k on the engine. The engine/turbo system was tuned once on 8/18/07 by Pherable.net (John Vega) and has run flawless ever since. I have performed three oil changes and one change of spark plugs.
All power accessories function as they should. Including power steering and cruise control. There are no oil leaks, no coolant leaks, or funny noises.
I purchased the car completely stock on 3/31/2006 with 89,xxx miles on the original odometer. Always a Florida car with absolutely no rust.
The instrument cluster indicates good operating temperature, good idle, no check engine lights, good idle afr on the wideband, and a healthy engine with 22inches of vacuum at idle.
Interior
Window Tint
AEM Uego wideband
Apexi boost gauge
B&M pro shifter
ITR shift ****
ITR shift boot
Sony cd player
Boston and Alpine speakers
Exterior
16" Rota GT3
New Falken 452 tires (215/40/16)
1piece headlights with Silverstar bulbs
Nokya yellow AUX bulbs
EG front lip
Suspension
K-sport full coilover 36 way adjustable
Omni Power adjustable front control arms
ITR front strut bar
Rear VTEC sway bar and lca's
Drilled rotors
Akebono PRO AC+ brake pads
Engine
B18B shortblock
81.5mm CP pistons & rings - blue printed
EAGLE forged rods
OEM bearings blue printed (main & rod)
Canton Mecca catch can & fittings
Decked .001 for straightness
New OEM ITR timing belt
New OEM ITRwater pump
New OEM ITR oil pump
Prothane motor mount insert (3)
B16 cylinder head
CC'd and polished combustion camber
Ferrea stainless valves
Bronze valve guides
ITR valve springs
Crower chromoly retainers
98 spec ITR cams
Edelbrock Victor X manifold - ported & powder coated
King Motorsports OEM ITR bored to 65mm throttle body
SKUNK2 Pro series cam gears
Powder coated JDM valve cover
King Motorsport manifold studs
TRANSMISSION
B16 1-4 with LS 5th
SPOON LSD
Competition Clutch stage 4
NEW oem axles
ACT 12lb flywheel
Brand new OEM Del Sol shift linkage
TURBO
INLINE PRO SS t-3 manifold
Turbonetics 63ar stage 3 turbine, 70ar compressor = aprx 54trim
3" downpipe and 3" SS exhaust
2.5" intercooler piping w t-bolt clamps
Spearco intercooler
ECTune by Phearable.net (street & dyno)
GM 3bar map sensor
Tial wastegate merged into downpipe
Turbonetics Evolution bov
FUEL
Walbro 255lph HP
Aeromotive fpr, with water filled gauge
Braided fuel lines with AN fittings
STR fuel rail
Precision 780 injectors
OEM injector driver plug and play
Old Sep 10, 2012 | 11:29 AM
lzylst's Avatar
Default Re: For Sale - 1995 Del Sol Si LS/Vtec Turbo
Feel free to ask any questions.
Old Sep 12, 2012 | 05:28 AM
lzylst's Avatar
Wacky Wednesday!
Old Sep 13, 2012 | 06:47 PM
lzylst's Avatar
Ttt
Old Sep 13, 2012 | 07:12 PM
rey_boricua's Avatar
bump
Old Sep 14, 2012 | 08:54 AM
lzylst's Avatar
TGIF!
Old Sep 15, 2012 | 05:28 PM
lzylst's Avatar
Just returned from a 91mile road trip to visit a friend. 100,635 miles on the chasis now.
Old Sep 16, 2012 | 12:09 PM
Arubiccube's Avatar
Looks nice, looks like a great build too. I think people are just skeptical on buying a Del Sol with a turbo @ 8k, if i didnt have the s2k, i would def. be interested.
Old Sep 16, 2012 | 12:55 PM
AllMotorRP's Avatar
Any numbers or bay pics?
Old Sep 17, 2012 | 05:02 AM
lzylst's Avatar
I understand you completely and thanks for looking. I chose the Del Sol because it is like a convertible with the targa top and slide down rear window. The cabin room is significantly larger than a S2000. Anyone looking is welcome to make an offer hence OBO. I have stacks of receipts to give to the new owner. My address is on the receipts so that is why there are no pictures of the receipts.
Btw I am an older professional enthusiast. Sorry for not having any of the normal fan boy items.
Old Sep 17, 2012 | 05:09 AM
lzylst's Avatar
Thank you for inquiring. There is an engine bay picture posted. I am not a fan of posting HP numbers to sell a car. The numbers are right in line with almost every other Ls/vtec on a mid size turbo....300ish on 10psi. The HP depends on how much you turn up the boost.
Old Sep 19, 2012 | 07:27 AM
lzylst's Avatar
Ttt
Old Sep 20, 2012 | 01:53 AM
chaos_cascade's Avatar
Nice price not crack pipe bump. Hope this makes it out to Vegas this year. Consider doing a running video to help sell it. Must be very fun to drive.
Old Sep 20, 2012 | 06:04 AM
lzylst's Avatar
I went to Vegas once about 5yrs ago to see the "strip". No intentions of ever going back.
Maybe a video would help, pleasing everyone is difficult.
Old Sep 24, 2012 | 06:07 AM
lzylst's Avatar
Ttt
Old Sep 25, 2012 | 08:30 AM
lzylst's Avatar
Ttt
Old Sep 25, 2012 | 04:36 PM
SirProject's Avatar
nice del sol. wish mine was that clean but im working on it..very slowly
bump it up for ya
Old Sep 26, 2012 | 10:09 AM
lzylst's Avatar
bump it up for ya
Thank you. Keep at it! Mine didn't get this way over night.
Old Oct 3, 2012 | 08:16 AM
lzylst's Avatar
Ttt
Old Oct 11, 2012 | 05:17 PM
mk3white's Avatar
bump for you, his cars are immaculate
Old Oct 24, 2012 | 08:15 AM
lzylst's Avatar
Ttt
Old Nov 13, 2012 | 05:16 AM
lzylst's Avatar
Bump
heathzx
Oct 4, 2014 07:30 AM
lzylst
Nov 28, 2012 07:07 AM
mikehtiger
Dec 31, 2009 10:44 PM
yoRt
Aug 14, 2009 04:54 PM
delslow94
May 11, 2004 01:16 PM
