b18 swap starting probs
Old Sep 8, 2012 | 11:20 PM
BIGef's Avatar
Default b18 swap starting probs
I have a 1989 civic sedan Dx b18a1 obd1 swap.
I bought the car with integra ghetto rigged interior and engine wiring harness.Car starts but runs like ****/rich.
Bought a 89 sedan shell and swapped out the whole interior wiring.
Bought a dpfi to obd1 and also bought a obd0-obd1 ecu jumper harness.
The car wont start/crank. No clicking on the starter.
Main relay clicks i can smell fuel. Fuel pump primes.
Checked fuse, ground, etc.
Cant seem to find the prob.
Any help appreciated
Old Sep 9, 2012 | 12:00 AM
csingham's Avatar
crazy mad murdock
Default Re: b18 swap starting probs
So you swappe the wiring just from the Interior? Engine harness? Seems you have to trace the wires if nothing is cranking. Are you getting a spark?
Old Sep 9, 2012 | 01:12 AM
BIGef's Avatar
yes basically everything.
trace the wires seems to be good. headlights and everything work.
i cant check for spark cause it doesnt crank.
no click on starter
Old Sep 9, 2012 | 05:19 AM
BIGef's Avatar
got my car to start,
found out i forgot to put the starter relay.
got the starter relay from the integra ghetto wiring.
started right up.
But it start then dies. takes couple of tries to get it to idle.
idles about like 100-300 very low idle.
I can also hear really loud hissing noise from the intake manifold.
Old Sep 9, 2012 | 06:11 AM
VegaS10's Avatar
That would be a vacuum leak.
Old Sep 9, 2012 | 05:17 PM
BIGef's Avatar
Can anyone show me p75 intake manifold hose diagram
davidayala831
Dec 1, 2017 12:15 PM
eghatch9295
Apr 28, 2011 05:26 PM
larryc0056
Oct 25, 2010 06:24 PM
hondacivic90zc
Nov 26, 2008 02:43 PM
EGHatchy
Jul 11, 2002 11:24 AM
