Boosted F23a1
Well i have Fully Rebuilt my Girls F23a
New wiseco Pistons,Rod's,Rings,Head w/Bisimoto stage 2 Cam
130 amp Alt, new Dizzy, all Seals and gaskets ,Crank Sensor,Timing,Both O2's,....
now, I WANT TO BOOST IT XD
Was looking at a "Flanged" T/3 and 4 Turbo so i can weld the downpipe or would a internal wastegate be better?
cause i wanna keep the a/c..
I planned on Getting a Chipped and Tuned P28 ECU for it anyway for the cam i need an Adapter for the harness i gotta find 1st
could anyone tell me am i missing something below?
450cc injectors, <-- This too much?
AEM Fuel rail and Pressure Reg
Fuel Pump
Manual Boost Controller
Turbo/and Manifold
Boost Gauge
feed lines
Intercooler/Piping and Blowoff valve
Then i slap it all on with the Plug and Play P28?
Hopefully? lol
Fuel Pump
Turbo/and Manifold
Boost Gauge
feed lines
Hopefully? lol
What compression ratio is the engine at right now...what Wiseco pistons did you instal?
depends on boost level, you will require a tune to find out, 450cc might be too small.
What are your power goals?
No need for the fuel rail. Aromotive makes a better fuel pressure regulator.
Fuel Pump
What pump were you considering, 255lph?
Turbo/and Manifold
Boost Gauge
feed lines
There is no such thing as a plug and play P28. A chipped OBD1 (P28) ECU will require tuning. There is no way around tuning, you will need to find a local tuner to work with on this build.
Fuel Pump
Turbo/and Manifold
Boost Gauge
feed lines
My Power goals is Not much, maybe 5-8lbs of boost? more for looks and sound, its my Girls car
but im starting to like it so it may end up my car as well if she gets this Toureg
The Compression right now is changed to 11:5:1(by the Piston kit specs)im not sure what the stock was
im using the wiseco Pistons, they were built to order, tops are scalloped(gas Ports)
and Bisimoto H beam connecting rods and pins...
here is the link to the "P28 ECU" thats supposedly chipped and tuned:
http://www.ebay.com/itm/190433527787?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649[/URL]
i never tuned or chipped a ECU so i dont know but thank you for telling me
y0whuddupb
Mar 23, 2008 07:50 PM
y0whuddupb
Jan 28, 2008 10:37 AM
