Auto trans problem
Old Sep 8, 2012 | 01:51 PM
turbo82's Avatar
Icon6 Auto trans problem
Got a friend with an accord that has a F22 in it. The problem is, when you first start the car it will go in all gears. But after a little while it won't go in any gear. The fluid is good, at the correct level and not burnt. I don't know the condition of the filter. This has got me baffled. Any help is appreciated.
Old Sep 9, 2012 | 06:46 AM
Lost Again's Avatar
Default Re: Auto trans problem
It would be nice to know what year this is but anyway.
Any stored codes?
Old Sep 9, 2012 | 02:10 PM
turbo82's Avatar
Oh it's a 96. Don't have a code reader to read the codes. I'm trying to find one now. I'm just try to use all my sources to help a friend. I'm not much help as I have no experience with auto transmissions.
Old Sep 9, 2012 | 02:27 PM
FRANKENSTIEN813's Avatar
sounds like its on its way out the door, Whats the Mileage?
Old Sep 9, 2012 | 02:52 PM
igotthaspirit's Avatar
Well first of all it has no filter. Are you checking the fluid level running or off? Hondas should be checked when the engine is off and preferably when everything has pretty much cooled down.
Old Sep 9, 2012 | 03:18 PM
turbo82's Avatar
14x,xxx. he's trying to avoid replacing it if he doesn't have to. Not worth puttin a new trans in it nor rebuilding it, if it's gonna cost almost as much as the cars worth.
Checking it when it's off in park after one heat cycle
Old Sep 9, 2012 | 05:03 PM
i noticed alot of the "auto" accord tranny's go around that mark, can find a used one on CL Cheap and 2 dudes get it done in a few hrs i did mine for $500 and some change DIY
Goodluck bro, hope its not the issue but 140Kmiles sounds about right
Old Sep 9, 2012 | 06:21 PM
jdmcertified909's Avatar
no filter??? lmao what are you on crack? ive opened two of these and they do have a filter in them lmao
Old Sep 9, 2012 | 07:41 PM
No actually you must be on crack if you think Honda transmissions have filters. Only thing they have is a magnet on the drain plug and a magnet stuffed inside. Think before you speak moron
Old Sep 9, 2012 | 10:17 PM
really??? so what i saw when i opened up my two transmissions wasn't a filter.
Old Sep 9, 2012 | 10:21 PM
i wonder what this is hear????? http://www.oreillyauto.com/site/c/de...0073&ppt=C0338 mmm i wonder why they list that its compatible with honda transmissions.. same here http://www.makcotransmissionparts.com/PX4B.html .... and here read on http://wiki.answers.com/Q/How_do_you...nd_where_is_it
oh and not to forget would you mind telling me why on my manual it says that its inside the transmission???? plz tell me what part #1 is on this picture
Old Sep 9, 2012 | 10:24 PM
so should i post the parts list for that picture of my manual or are you done trying to make me look stupid. and not to say IVE OPENED TWO OF THESE TRANSMISSION OPEN INCLUDING THAT OF A 97. BOTH HAD FILTERS INSIDE. so i think this time you should be the one to think before speaking *MORON*
Old Sep 10, 2012 | 12:43 AM
MAD_MIKE's Avatar
MM Gruppe B
I would check transmission pressure. Keep a gauge attached and drive the car until it stops moving, note if there is a pressure difference.
If the fluid has never been changed it is possible that the filter inside the transmission is picking up enough particles to block the sump. Turn off the engine, the pump stops pulling fluid, and the particles stuck to the filter fall off the media and the pickup is clear enough to work again.
Drain and change the fluid. If the drain plug is covered in material then it has been due for a change.
Check the H4A link in my sig.
Old Sep 11, 2012 | 09:19 AM
turbo82's Avatar
Thanks, I will check that out.
Old Sep 11, 2012 | 10:08 AM
Bad_dude's Avatar
To the OP:
Just to be clear, b/c the other 2 guys were busy, the tranny does have a filter but it's not some thing you have to replace unless you drop the tranny. So all you need to do is replace the fluid with new Honda's fluid only. It will take about 2.5-2.7quart. Then drive it for about 500 miles drain it again and replace. Then once more at 1000 miles. That should leave about 80% new fluid mix with old.
I would pull the TCU to check the caps condition. I think any shop would have a code reader to give you the answer.
Old Sep 13, 2012 | 12:14 PM
turbo82's Avatar
Worked on it today. Just changed the the fluid and it was dirty as ****. It was full of metal shavings like the fluid was never changed. On the first change the car acted way better but the problem still happened. Before it would take about 2 minutes of rest before it would move again, now it takes about 30 sec. I'm thinking the filter is gettin so stopped up, that it's just not letting the fluid pass thru properly.
I'm going to drop the trans and split it to look inside. Hopefully a good cleaning will fix it. Stay tuned....
Koko4
Jan 12, 2015 03:31 PM
beatnu50
Jun 5, 2008 07:30 PM
2doorcorolla
Feb 15, 2008 08:05 AM
ferio252
Oct 28, 2007 04:40 PM
wengmc
Oct 25, 2007 07:02 PM
