Drilled or Slotted rotors???
Old Sep 8, 2012 | 12:28 PM
Motionek55's Avatar
Default Drilled or Slotted rotors???
Im in the market for upgrade in the brakes department, ive been looking at dif. rotors and wondering A. whats the dif between drilled and slotted rotors besides the obviouse and B. which would you recommend?
Old Sep 8, 2012 | 12:31 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Drilled or Slotted rotors???
No research on your own huh? The overwhelming majority of people will tell you blanks are best. The drilled &/or slotted variety are touted mainly for looks. Funny though. They stop my car just the same.
Old Sep 8, 2012 | 12:32 PM
Deetz's Avatar
Crazy Honda Guy
For the street?? A brembo blank will out perform both a slotted and a drilled rotors, more surface area.
If you are hell bent on a choice of those two styles, a slotted rotor is a better choice as they don't get the heat cracks for what drilled rotors are know for as they get older
Old Sep 8, 2012 | 12:33 PM
The Grumpiest
Never had a crack show up in any drilled rotor I've ever run.
Old Sep 8, 2012 | 12:34 PM
Deetz's Avatar
Crazy Honda Guy
^^ happened to two of my personal vehicles now
Old Sep 8, 2012 | 12:38 PM
Motionek55's Avatar
ok cool, thanks guys. Ive researched a liltle and yes it hard to decide what to get when u hear all the same things and when you have 3 choices i like to know personal opinions.
Old Sep 8, 2012 | 01:05 PM
furious94ls's Avatar
You don't need them unless this is a show car. In that case spend the money and get ones made that way. They have less surface area and if the company drills them out themsleves the rotors become weak.
Cars that come from the factory with them have the appropriate setup with pads/calipers and rotors.
Old Sep 8, 2012 | 01:07 PM
94preludeguy's Avatar
It'd be more beneficial to invest that money into a rear disc swap.
Old Sep 8, 2012 | 01:33 PM
98civdx's Avatar
Master Detailer
Just get blanks.
Drilled and slotted rotors are for looks.
Old Sep 8, 2012 | 01:42 PM
Deetz's Avatar
Crazy Honda Guy
umm, no, lol
Rear disk brakes on a Honda make up only 20-25% of braking. On Honda's, rarely does a rear disk setup decrease stopping distance......it's all in the front. Bigger calipers and rotors in the front are where performance in brakes can be had.
Old Sep 8, 2012 | 02:04 PM
Originally Posted by Deetz
umm, no, lol
There is absolutely no beneficial gain from using drilled/slotted rotors, which is why I said the rear disc swap is a better investment. Obviously bigger rotors/calipers would be a better investment as well. There are gains from the rear disk swap, but like you said they are pretty minimal.
mrbuff91
Suspension & Brakes
Sep 30, 2009 01:26 PM
d16lxciv
15
Apr 16, 2007 07:00 PM
JHD_DA
Aug 12, 2004 06:40 AM
tmekjian
May 10, 2003 04:04 PM
hb_racer
Apr 14, 2002 08:55 AM
