a del sol with a type "R" motor?
Old Oct 16, 2002 | 05:31 PM
Kaddo101's Avatar
Default a del sol with a type "R" motor?
Can you fit the new type R motor in the del sol? i was wondering because im buying a del sol and im not happy with the performance. yes i do have a dohc v-tech ingine too. do they sell conversion kits for the del sol transformation to a type R?
Old Oct 16, 2002 | 05:34 PM
rodrez.'s Avatar
Default Re: a del sol with a type "R" motor? (Kaddo101)
It's a B-series motor, it drops right in.
Old Oct 16, 2002 | 05:35 PM
976's Avatar
976
New User
Moddify that B16A2.
Or, spend some cheese and swap a B18C5(R type motor) in.
Hasport, or place racing motor mounts, drive axles, whole bunch more ****.
http://www.hasport.com
Old Oct 16, 2002 | 05:41 PM
EVIL Hx Coupe's Avatar
Default Re: a del sol with a type "R" motor? (w00t!)
Sell ur B16 block, get a B18 block and "Voila" Tq, more HP, and lots of potential.
Old Oct 16, 2002 | 05:43 PM
94si94cx's Avatar
Default Re: a del sol with a type "R" motor? (Boost Pressure)
If you're going to take that risk, you might as well just get the b20 block and get even more torque for about the same amount of cash. Oh and just a side note, the DOHC VTEC motor for the del sol is b16a3
Old Oct 16, 2002 | 05:47 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: a del sol with a type "R" motor? (Siturbohybrid)
i think the new type r engine is the k20 and it probably will fit...but its gonna cost the dough.....also i believe its vtec not vtech...vtech is a phone stunna
Old Oct 16, 2002 | 05:56 PM
94si94cx's Avatar
Default Re: a del sol with a type "R" motor? (CiRcUiTsi)
Yes, the new Type R motor is the k20a and it CAN fit in a car, but just as a f22 CAN fit in a Civic, or a f20 CAN fit in a CRX. It spins the opposite direction than the conventional d-series and b-series motors that the del sol is used to seeing and requires special mounts for everything. I'm sure there would be a weird torque on the chasis too. I'm sure though he is referring to the b18c5 motor, or at least i hope so. If not, we may be seeing this car in a magazine.
nitrotiger
Jan 1, 2011 06:24 PM
solspeed
Jun 5, 2006 04:40 PM
civicek00
Jun 17, 2005 03:40 PM
Daikirai
Sep 29, 2003 06:13 PM
E Swift
Jan 28, 2002 09:10 AM
