b18c turbo valves Compression
hi
Now I was re-building my b18c turbo. And i want to know Any of the valves should be used . Standard valves Compression or valves high Compression ,and who mach power i will gite
my setup :
RC 550cc Injectors
255 welpro fuel pump
koyo radiator
moshimoto thermostat-fan switch
Crank B20 NON VTEC
CP PISTONS
Manley rods LS
Bearing rod /main
ARP head studs
Type R oil pump
aem fuel rail
turbo M24 Garret 48 A/R
AEM ECU
NOTE: I use google translator
my setup :
RC 550cc Injectors
koyo radiator
Crank B20 NON VTEC
CP PISTONS
Manley rods LS
Bearing rod /main
ARP head studs
Type R oil pump
aem fuel rail
AEM ECU
H22AFerio
Oct 9, 2011 11:23 AM
mr. wu
Jun 28, 2003 12:57 AM
