d15b1/z6 mini me
Old Sep 7, 2012 | 05:14 PM
jchope's Avatar
Default d15b1/z6 mini me
ok so i have a bad valve seal on my head and with a friend giving me his z6 head im gona do a mine me
i know i need
z6 timing belt
z6 head gasket
and y8 cam gear
as far as the mpfi swap what all do i need and should i switch to obd 1 or can i stay obd o
Old Sep 8, 2012 | 12:24 PM
jchope's Avatar
Default Re: d15b1/z6 mini me
anyone ive been reading and im confused
Old Sep 9, 2012 | 05:14 PM
dephtone's Avatar
If you are going to do a mini me swap, just convert the car to OBD1 so you can run a P28 ECU from a d16z6, in which you will need OBD0-1 conversion harness for Distributor as well as the ECU.
Below is a link how to convert the car from DPFI to MPFI. It's actually not that tough at all.
http://www.b20vtec.com/forums/techni...-diagrams.html
Old Sep 13, 2012 | 04:53 PM
91grape's Avatar
theres a guy on ebay that makes the harnesses for the swap and they run about 135. i thought it was worht it, completely plug and play.
http://www.ebay.com/itm/88-91-HONDA-...2b46ec&vxp=mtr
Old Sep 13, 2012 | 04:54 PM
91grape's Avatar
he also makes the jumper harnesses, but im sure you could probably find one a little cheaper somewhere
Old Sep 14, 2012 | 12:29 PM
jchope's Avatar
i may be getting a hole z6 for free and i was wondering if i could use a obd1 engine harness instead of doing the conversion
Old Sep 14, 2012 | 02:10 PM
DCRB's Avatar
no. you have to convert your car to mpfi as the factory wiring is wired for 2 injectors
Old Sep 14, 2012 | 06:37 PM
jchope's Avatar
but if i got rid of all the factory engine harness and replaced it with and obd1 engine harness i wouldnt have to worry about that
Old Sep 14, 2012 | 06:44 PM
v4lu3s's Avatar
RTFM
to do that you will also need to replace the chassis harness....or at least change a lot of plugs and add lots of new wiring.
Arthas
24
Sep 26, 2010 11:08 AM
crxzcracer
Sep 23, 2007 07:24 PM
yellowjdmcrx
14
Dec 11, 2005 08:52 AM
Rydaddy
Nov 2, 2003 04:27 PM
tenzoRhatch
Oct 26, 2003 08:07 PM
