can rod pin bearing pins be swaped?
Old Oct 16, 2002 | 05:06 PM
turboex's Avatar
Default can rod pin bearing pins be swaped?
ok my new pistons are to samm for the rods and they are really lose. so can i swap the bearing in the rod for a bigger size?
Old Oct 16, 2002 | 05:15 PM
Jared's Avatar
Default Re: can rod pin bearing pins be swaped? (turboex)
what the hell are you talking about?
Old Oct 16, 2002 | 05:34 PM
HybridKOOP's Avatar
Default Re: can rod pin bearing pins be swaped? (Jared)
Old Oct 16, 2002 | 05:43 PM
rjardy's Avatar
are you saying that your wrist pins dont fit into your new pistons correctly?
im confused
Rob
Old Oct 16, 2002 | 06:02 PM
turboex's Avatar
Default Re: can rod pin bearing pins be swaped? (rjardy)
correct the wrist pins for my new pistons are like 21mm and the rods i have are at least 22 or 23mm
Old Oct 16, 2002 | 06:12 PM
rjardy's Avatar
I think that you have to get new rods.
Rob
Old Oct 16, 2002 | 06:27 PM
Sonny's Avatar
He has a custom set of Crower rods with a ~23mm wrist pin hole and matching JE pistons with a 23mm wrist pin. As you know, the standard B series size is 21mm. Can he put a larger bushing in the Crower rod? Crower makes inserts like this that allow a D series (19mm) wristpin to be used in an LS rod.
Sonny
Old Oct 16, 2002 | 06:42 PM
turboex's Avatar
Default Re: can rod pin bearing pins be swaped? (Sonny)
yeah we dont wanna have to get new rods. as it would be hard to sell the ones i have with the custom pin size. also i was thinking about having the machine shop enlarge the pin hole in the piston, but im not sure yet. all ideas welcome. thanks sunny for the help so far
kpjo4
Mar 11, 2010 07:56 PM
siis2fast
Apr 20, 2005 09:34 PM
boost fed ls
Jan 29, 2005 04:20 AM
Sh4rky
May 24, 2002 08:37 PM
